Is Windows XP x64 supported
Discussion in '3CX Phone System - General' started by htcomm, Jul 31, 2008.
  1. htcomm
    Jul 25, 2008
    17
    I've had a look in the faq and it states that Windows XP x64 is currently untested and unsupported for use with the 3CX.
    3CX say 'to be tested in Q2 2008'.
    Is anyone running Windows XP x64, or are 3CX in a position to confirm their support for this OS ?
  2. Anonymous
    Anonymous Guest
    The system works in our experience, but is not officially supported yet.
    Thanks,
