Is XP OK?
Discussion in 'Windows' started by cfive, Jan 13, 2016.
  1. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Will the current version 3CXPhone for Windows work on XP? (v14 system).
    New prospect has some XP computers that are scheduled for replacement, but we'd like to proceed with 3CX before that happens.
    Thanks - Les.
    10,750
    285
    I haven't come across a list of which OS's are supported for the 3CX phone for Windows, as there is with the PBX software. I'm assuming that it was designed around the same systems that are used with the PBX, but, you really don't have much to loose in trying to install it, it will either work, or not. If it's an evolution of previous versions, then there is a good chance it will work
  3. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    It's kind of important for the client, as he doesn't have a definitive answer from his HO as to when the XPs are retired. I may have to dig up an xp box, if nobody else chimes in.
    Thanks, Leejor.
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    It looks like XP is out of the question, as .net 4.5 is required for 3CXPhone and I don't believe it will install on XP. It's possible that Mono (http://www.mono-project.com/) would work, but I don't know that I'll be testing it.
    - Les.
