Is Yealink T12P supported?
Discussion in 'Windows' started by kubasz, Jul 10, 2011.
  1. kubasz
    Jul 10, 2011
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    No it is not supported and in fact been discontinued. Please chose another supported phone.
    Thanks,
    Nate
  3. willow
    willow Member
    Mar 1, 2011
    471
    though it is not support, you could still try it and see if you can get it to work properly. I have gotten alot of phones to work over the years that are not support. Just because it is not supported doesnt mean that it will not work.
