ISA Server 2000 with 3CX?
Discussion in '3CX Phone System - General' started by nienunb, Apr 17, 2009.
  1. nienunb
    Mar 10, 2009
    15
    Hello all,
    Quick question here:
    I've been reading up about the issues with Microsoft ISA server 2004 and 2006, and their inability to create static port mappings, which interferes with 3CX.
    Does this issue also affect ISA Server 2000? It seems that creating a Server Publishing rule with the correct port numbers achieves a static port mapping. Or am I missing something here?
    Thanks for any feedback!
    nienunb
  2. ctsxiyou
    Apr 12, 2009
    7
    Why not test ISA Server 2000 with 3CX to find out the answer yourself?
