ISDN Bri Gateway
Discussion in '3CX Phone System - General' started by Kris4Fizz, Aug 2, 2010.
  1. Kris4Fizz
    Aug 2, 2010
    I'm looking at replacing an existing VoIP PBX supplied by Telappliant, with the 3CX VoIP PBX.
    Currently the PSTN system is ISDN2e supplied by BT. The existing VoIP PBX talks to a Parlay VoxIP Bri Gateway, I imagine this will be sufficient to work on the 3CX PBX?
    Can anyone point me in the right direction for configuring this gateway with the 3CX PBX?
    Thanks in advance.
    Regards
    Kris
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    Parlay have 3CX down as a SIP server that they interoperate with. 3CX as far as I know do not support it, but Voxtream do so I suggest that you contact them. Look at http://www.voxtream.com/p349.asp for interoperability.
    It ought to be straightforward.
    Richard Crabb
    http://www.dorsetphonesystems.com
