ISDN Cards
Discussion in '3CX Phone System - General' started by gaiacraig, Jan 9, 2008.
  1. gaiacraig
    Jan 8, 2008
    Which ISDN cards are supported by 3CX?
    I have an ISDN-30 and would like to connect my PBX to it to replace my Asterisk server.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The answer should be NONE at this moments. I'm not sure if it will be supported later.
  3. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    3CX supports currently no cards. You need stand alone gateway. I think I saw on this forum report about AudioCodes Madiant 1000 gateway which would fit your requirements.
    Thank you
    Marcin
  4. gaiacraig
    Jan 8, 2008
    Thanks for the input.
    Do you know, also, if the 3CX system supports GSM calls?
    I have 4 GSM SIM cards installed in my Asterisk PBX and I would like to migrate these too.
  5. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    If GSM gateway support SIP, I dont see any reason why it should not work with 3CX.
    I'm going to test:
    http://www.portech.com.tw/eweb/MV370/mv370.htm
    In near future.
    Thank you
    Marcin
  6. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    3cx does not do internal PCI cards like Asterisk. It does external gateways. Any asterisk server hardware will not work with 3cx.
  7. tab
    tab
    Aug 10, 2007
    85
    I'm testing an mv-370, but haven't succeed to make incoming calls to 3cx. In header sending gsm gateway 'to' field is 'user_ip' and I can't change it.
