ISDN Gateway
Discussion in '3CX Phone System - General' started by npiersma, Jan 26, 2007.
  1. npiersma
    Dec 30, 2006
    55
    Just a general routing question.
    Is it possible to use a ISDN card for call routing to the outside world?
    Having a ISDN (digital) connection, converting it into analogue, and then converting it back to digital (FXO ports) doesn't really make sence.
    Are there any ISDN gateways boxes (maybe from Grandstream) or a solution where we use a CAPI card?
    Niels
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    We have performed some preliminary tests using ISDN to VoIP Gateway devices, and the results are positive.
    I will post more details shortly.
  3. marcovalli
    Feb 26, 2007
    14
    ISDN CAPI CARD
    Hallo, I speak english a little bit.... I would to know if there are some news to SDN CAPI CARD.
    Thanks :?:
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    305
    its possible to connect ISDN lines via an ISDN VOIP Gateway such as from Patton. Please see the FAQ for the list of supported devices.
  5. dionh
    Mar 3, 2007
    23
    Is anybody using a PRI gateway with more that 8 channels?
    If so what gateway are you using? Have 3cx tested any PRI gateways these tend to be expensive so dont what to take pot luck at
