ISDN
Discussion in '3CX Phone System - General' started by jits04, May 5, 2007.
  1. jits04
    May 2, 2007
    76
    My customer has two ISDN line (4 number). What do you suggest to buy for the following solutions (already tested with 3cx software)?
    1) connect with actual ISDN PBX ( I think less expensive)
    2) replace the actual ISDN PBX
    What are difference from the two solutions?
    Many Thanks in advance
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    I suggest using a PATTON isdn VOIP gateway. And remove the old phone system...
