ISDN30 UK
Discussion in '3CX Phone System - General' started by impaddy, Jun 28, 2011.
  1. impaddy
    Jun 3, 2011
    10
    After playing around with 3cx for a while now trying to get it to work with the outside world I have been made aware that we infact have an ISDN30 PRI line rendering the linksys SPA3102 useless I assume?
    Does anybody have 3CX working in the UK with an ISDN30 line? If so what Gateway are you using?
    Thanks in advance
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, the SPA3102 is an analog device, ISDN is digital
    you would need a Digital Gateway for ISDN, Patton do some good gateways
    You could go with a Patton SN4960/1E15V/UI (1 x T1/E1/PRI VoIP IAD, 2x GigEthernet, UI power, 15 VoIP Channels; field upgradeable to max of 30 channels) at cost of £1485.00 We provide this via next day delivery
  3. impaddy
    Jun 3, 2011
    10
    Will the Patton 4940 accept the 3cx configuration for the 4960?
    Thanks in advance.
  4. davidbenwell
    Apr 27, 2010
    704
    Not tried this, however you may need to change the template to get some of the features to work.
