ISO Boot HyperV Generation 2
Discussion in '3CX Phone System - General' started by OGUER, Jul 21, 2017.
  1. OGUER
    Jul 21, 2017
    we can't boot ISO on a Generation 2 VM (HyperV - mount with SCSI)
    (secure boot is off)
    it's working with Generation 1 (mount with IDE)
    the default debian 8.6 ISO work perfectly.
    What's wrong ?
  2. LyonAdmiral
    Aug 10, 2015
    51
    I was under the impression that the 3CX ISO was not EFI boot compliant or capable and that is why it does not work under HyperV Generation 2.
