ISO Linux Install - How to upgrade
Discussion in '3CX Phone System - General' started by ceberly, Dec 14, 2016.
  1. ceberly
    Dec 14, 2016
    So, I installed v15 last week from the ISO option. How do I verify which service pack I'm running and how do I upgrade? In the docs, I only see reference to the windows update procedure, and don't see anything in the Web Console for system updates... just addons, etc.
    Thanks!
  2. ALuisPV
    Mar 7, 2016
    28
    Hi ceberly ,
    in the Management Console, you can see the version of 3CX in Information --> License
    And, in the Management Console, in Updates, you will see that there will be a Service Pack update once you have a pending update of a Service Pack. If your system is updated, you won't see information about SPs.
    Best Regards.
