ISPTelecom + 3CX
Discussion in '3CX Phone System - General' started by Zach, Oct 3, 2017.
  1. Zach
    Oct 3, 2017
    I am new-ish to 3CX and am having trouble with it.
    Setup:
    STATIC Public IP
    - Ports forwarded UDP
    - 5060 / 9000-9225
    - 10000-40000
    ISPTelecom requires IP Authentication (not username/password)
    I had the provider do a PCAP and it looks like 3CX isn't responding to the SIP INVITEs.
    Thank you for your help.
    Z
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Port forwarding ranges are not correct, search for document on the topic in 3CX site. However this should not be the issue. Analyze what's happening into the capture file, there could be many reasons. First correct the port ranges and run the firewall checker in 3CX.
    #2 sip.bg, Oct 3, 2017
