Issue call with +[number] after update to SP4
Discussion in '3CX Phone System - General' started by Giorgio Ruga, Dec 19, 2016.
  1. Giorgio Ruga
    Dec 19, 2016
    From the update of the SP4, we are not able to call with format +[number], but only with 00[number].
    Our Process E164 Numbers configuration is the one attach.
  2. jan.schreiber
    Oct 14, 2016
    6
    same here, that's really annoying because most numbers we mark and dial through CTI does not work anymore. :-(
    Kind regards
    jan
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Dear Giorgio,
    Are you calling to your own country? (Switzerland +41)
  4. jan.schreiber
    Oct 14, 2016
    6
    yes, all numbers i did try where to my own country.
    thank you and kind regards
    jan
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,444
    463
    Is the option replace + with 00 selected in the 3CX client for windows? You can find this setting by clicking Settings/ Configure Account/ Double click on your account/ Advanced settings/ Scroll to the bottom and check if setting is enabled
  6. dab
    dab
    Nov 1, 2009
    67
    I have the same problem. I've changed the setting in 3CX client for windows, but there's no change. I can't call e164 formated numbers.
  7. YiannisH_3CX
    May 10, 2016
    6,444
    463
    Are you using CTI? Try disabling the E164 processing and create an outbound rule that strips the + and adds 00 and see if that works
  8. dab
    dab
    Nov 1, 2009
    67
    I'm in Softphone Mode. With disabled E164 processing and the suggested rule it works, thanks.
