Issue creating Webinar via Web client in V15.5 SP3
Discussion in '3CX Phone System - General' started by TheDestinyGroup, Feb 14, 2018.
  1. TheDestinyGroup
    Jun 30, 2015
    24
    11
    There is a issue with creating a Webinar via the Web client in V15.5 SP3 as you get an e-mail address is invalid error when trying to add an e-mail address.
    The workaround is to ensure you select "3CX (direct eMail)" from the "Calendar" drop-down list before selecting "Webinar (classroom)" from the "WebMeeting Profile" drop-down list.
    It appears that is the "Calendar" drop-down list has anything other than "3CX (direct eMail)" selected when you choose "Webinar (classroom)" from the "WebMeeting Profile" drop-down list it fails to properly update some settings even though it changes the "Calendar" drop-down list to "3CX (direct eMail)" and disables the drop-down list.
    Les
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Hello The DestinyGroup,
    you are right and we are aware of this case and have a correction ready for update 4
