Issue in pathing
Discussion in 'Call Flow Designer' started by gustavskii, Mar 2, 2018.
  1. gustavskii
    Jan 26, 2016
    57
    Hello
    for some reason I couldn`t use folders and files that starts with letter N in pathing for CFD
    for example:
    "C:\\CFD\\Calling\\numbers" - wouldn`t work
    but
    "C:\\CFD\\Calling\\fumbers" - would
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,345
    108
    Hello @gustavskii,
    Thanks for bringing this issue to our attention. I think that the problem is that \n is being considered the new line character. We need to investigate further and provide a fix.
    Meanwhile, you can use the other slash, which also works in Windows as a path separator:
    "C:/CFD/Calling/numbers"
    Kind regards.
    gustavskii likes this.
