Issue log to 3CX using FQDN From WAN?!
Discussion in '3CX Phone System - General' started by ahmedsza, Apr 26, 2017.
  1. ahmedsza
    Jan 4, 2015
    17
    I have one issue with FQDN
    The WebMeeting from lan work perfectly, but cannot login from outside
    I configured every things,
    Firewall is green
    In my fiber modem I configured port forward the following ports and point to 3CX Server
    5060
    5090
    5000
    5001
    443
    9000-9500
    Any help ?
    11,094
    327
    Did you actually run the 3CX Firewall Test with success?
  3. ahmedsza
    Jan 4, 2015
    17
    yes, and every things is green, even firewall on dashboard is green.
  4. BartLanz
    Apr 17, 2017
    7
    Do you have commercial internet access? I have seen ISP's block HTTP traffic to non-commercial accounts.
    Do you have a static IP or dynamic IP from your ISP
    Do you have more than one internet connection
    Do you have more than one Gateway on your network?
  5. ahmedsza
    Jan 4, 2015
    17
    Nothing block from isp
    I have dynamic IP
    Only one internet connection
    Only one gateway
  6. pact
    pact New Member
    Dec 16, 2009
    218
    41
    Hi ahmedsza,
    WebMeeting is hosted externally, are you talking about WebMeeting or the Web Management Portal?
    What URL are you using? (Feel free to obfuscate it)
  7. ahmedsza
    Jan 4, 2015
    17
    Thanks every one for your cooperation
    Actually, the web management is now working
    for web management when use https and port 5001 with FQDN its working fine,
    but still webmeeting and SBC not working, cannot resolve the FQDN
    please check the following image: second image from SBC logs
    [​IMG]
    [​IMG]
  8. ahmedsza
    Jan 4, 2015
    17
    I Re-Install the SBC in another machine and get the following error
    [​IMG]
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Is your FQDN actually resolving correctly to your public IP address? Does your IP change often?
  10. ahmedsza
    Jan 4, 2015
    17
    yes its resolve, and i can log in to Web management perfectly from outside without any issue using the following format:
    https://****.3cx.asia:5001
  11. YiannisH_3CX
    May 10, 2016
    7,358
    535
    In the config file of the SBC have you tried using the Public IP instead of the FQDN to eliminate any DNS issues? Does it connect then?
  12. ahmedsza
    Jan 4, 2015
    17
    just quick adding
    The WebMeeting now work perfectly without no issue
    The only issue now with remote ext using SBC
    I also enable use ext outside lan.
    Here the SBC log
    ERR | 20170427-134411.899 | 3CXTunnel | TUNL | 408 | TunnelTcp.cpp:262 | Bridge [3CXSBC15.0.61335] failure 'Unknown error' on TCP connection: exception while connecting
    ERR | 20170427-134443.304 | 3CXTunnel | TUNL | 408 | TunnelTcp.cpp:637 | Socket error (10061): exception while connecting at exception while connecting (TunnelTcp::process)
    ERR | 20170427-134443.304 | 3CXTunnel | TUNL | 408 | TunnelTcp.cpp:262 | Bridge [3CXSBC15.0.61335] failure 'Unknown error' on TCP connection: exception while connecting
    ERR | 20170427-134513.735 | 3CXTunnel | TUNL | 408 | TunnelTcp.cpp:637 | Socket error (10061): exception while connecting at exception while connecting (TunnelTcp::process)
    ERR | 20170427-134513.735 | 3CXTunnel | TUNL | 408 | TunnelTcp.cpp:262 | Bridge [3CXSBC15.0.61335] failure 'Unknown error' on TCP connection: exception while connecting
    And here my SBC Config:
    [Bridge/123456]
    Name=3CXSBC15.0.61335
    TunnelAddr=10.10.10.10
    LocalSipPort=5060
    ID=123456
    LocalSipAddr=192.168.11.139
    Password="123456"
    PbxSipIP=192.168.1.190
    PbxSipPort=5060
    SecurityMode=0
    TunnelPort=5090
    [General]
    FailoverInterval=90
    PrintStatsInterval=30
    ReconnectInterval=30
    [Log]
    Type=file # cout, cerr, file, syslog
    Level=ERR # "ERR", "NONE", "EMERG", "ALERT", "CRIT", "ERR", "WARNING", "NOTICE", "INFO", "DEBUG", "STACK", "ERR", "VERBOSE"
    File=C:\ProgramData\3CXSBC\Logs\3cxsbc.log
  13. YiannisH_3CX
    May 10, 2016
    7,358
    535
    From what i can see you have used a local IP on values tunnel address and PBXSipIP when it should be the public IP of the PBX.
    the local SIP address should be the local IP of the SBC.
    Can you update those values to the correct ones and let us know if that worked for you?
    Also make sure the tunnel password is correct. You can check by navigating to your PBX/settings/ security settings/ 3CX tunnel.
    Once you do the changes restart the SBC service
  14. ahmedsza
    Jan 4, 2015
    17
    Unfortunately same issue
    i configure as following
    LocalSipPort=5060
    ID=123456
    LocalSipAddr=192.168.11.139 (SBC IP )
    Password="123456" ( password i keep it simple from 1 to 6 )
    PbxSipIP=10.10.10.10
    PbxSipPort=5060
    SecurityMode=0
    TunnelPort=5090
  15. ahmedsza
    Jan 4, 2015
    17
    Any Help ?!!
  16. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    ... you know you need to restart the SBC service for the change to take effect I assume ?
  17. pact
    pact New Member
    Dec 16, 2009
    218
    41
    Hi ahmedsza,
    TunnelAddr= (This is the PUBLIC IP address of your 3CX system or your FQDN if using Dynamic IP)
    LocalSipPort=5060
    ID=123456
    LocalSipAddr= 0.0.0.0 (Set this to 0.0.0.0 so it binds to all addresses)
    Password="123456"
    PbxSipIP=(This is the PRIVATE IP address of your 3CX system, the one you use when you are internal to the system)
    PbxSipPort=5060
    SecurityMode=0
    TunnelPort=5090
    So just confirming, your public ip is 10.10.10.10 (Or you have removed your actual public ip?)
    Also when provisioning a phone you are selecting 'Remote via SBC' and specifying the local IP address of your SBC?
    When provisioning over an SBC you do not need to tick 'Allow outside of LAN' as the SBC acts as a VPN/Tunnel and the extension then appears as internal to the phone system.
    You should then see in the Logs of the SBC that phone at least attempting to register via the SBC, even if the SBC is not connected, this ensures you have the phone config correct at a minimum.
