- Joined
- Jul 4, 2013
- Messages
- 1
- Reaction score
- 0
Hi all,
my configuration is very simple. I have a Windows 2003 Server using MS Fax Service with T38 protocol connected to an extension of 3CX software, installed on other 2003 server.
I installed T38&FAX VOIP and MS FAX service on Windows 2003 in november 2012 and from this date my company users sent hundreds of fax without any issue.
Now when i try to send fax, MS Fax Service return error "There was no answer".
I'm sure that no change to T38, Ms Fax Service, 3CX was made. However i checked all configuratons that appear good.
During my troubleshoothing i discovered that when call a remote fax by the Voip phones (SNOM and YEALINK) i can hear handshaking start (less than a second) from it. But, after this... the silence :cry:
Further in some case line was dropped immediately.
(Obviously if i call same fax by a mobile or fixed phone i can hear all the handshaking sequence)
My VOIP provider says that no modify was made to our configuration.
So.... anyone has an idea to resolve my trouble?
Many thanks in advanced for you help
Regards
Regards
