Issue updating 3CX Cert
Discussion in '3CX Phone System - General' started by Gatesr494, Jan 10, 2018.
  1. Gatesr494
    Aug 28, 2017
    I am having a difficult time updating the certificate we use for 3CX. Currently running V15 and we are using a wildcard cert for our domain. I have alredy obtained the new wildcard cert through a request from a different server. So I need to know how do I update the cert when I don't have a .key file? Does IIS generate one when the cert is requested???
  2. Nathan Boyd
    Feb 2, 2017
    46
    11
    What I had to do on a few linux installs (as my SSL CA didn't like the native CSR) was generate CSR and complete the issuance of a cert from IIS, and then export the Cert from the the Windows Server. From there it should be a .pfx accompanied with a password for consumption.
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    As far as I'm aware, renewing your certificate is basically the exact same procedure as what you did when first issuing it, so the renewed certificate should be paired with the matching .key file.
