issue when I tried save the gateway
Discussion in '3CX Phone System - General' started by chico, Mar 21, 2017.
  1. chico
    Mar 8, 2017
    12
    When I tried to save the Gateway, 3cx give me this internal server error.
    I tried to restore a backup for a version 14 to 15.
    Internal Server Error(500)
    d__28.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__18.MoveNext()
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at Microsoft.AspNetCore.Builder.RouterMiddleware.d__4.MoveNext()
    at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.d__3.MoveNext()" class="ng-scope" style="box-sizing: border-box; overflow: scroll; font-family: Menlo, Monaco, Consolas, "Courier New", monospace; font-size: 13px; padding: 9.5px; margin-top: 0px; margin-bottom: 10px; line-height: 1.42857; color: rgb(51, 51, 51); word-break: break-all; word-wrap: break-word; background-color: rgb(237, 241, 242); border: 1px solid rgb(222, 229, 231); border-radius: 4px; height: 400px;">TCX.Configuration.Exceptions.ObjectSavingException: Commit failed on transaction Save ExternalLine.105 - '90002'
    at TCX.Configuration.PhoneSystem.WBatchUpdater.Commit()
    at TCX.Configuration.ExternalLine.DoSave(WBatchUpdater updater)
    at TCX.Configuration.ExternalLine.Save()
    at ConfigurationManagementModel.CfgItemBase.Save()
    at ManagementConsoleJS.Services.Editor.Save()
    at ManagementConsoleJS.Services.EditorService.SaveActiveObject(Int32 id)
    at ManagementConsoleJS.Controllers.EditController.Save(Int32 id)
    at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__28.MoveNext()
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @chico
    Did you just create the gateway or was it included in the backup? Can you tell us what gateway this is?
    The issue could be that the template of the gateway was very old and you may need to create a new config file for the device and re-create it.
  3. chico
    Mar 8, 2017
    12
    Hi, and thank for your reply.
    The Gateway is came with the backup.
    The issue, is I don't know when I tried to install a new gateway, don make the connection with the 3cx.
    Have a some phone to call to patton or to 3 CX for have a some support?
  4. 3CXNewbie
    Jul 18, 2013
    21
    I also have an error when I try to save a SipTrunk. Even without amendments, get following error if I open and save. Only on 1 of the trunks though.
  5. gregja1310
    Apr 19, 2017
    7
    i am getting the same error
  6. YiannisH_3CX
    May 10, 2016
    4,443
    282
    If you have 2 trunks /gateways change the auth ID on one so they are not the same. (empty is considered the same)
  7. gregja1310
    Apr 19, 2017
    7
    hi ,
    They are not the same, :
  8. YiannisH_3CX
    May 10, 2016
    4,443
    282
    @gregja1310
    Please check your inbox, i have sent you a p.m.
