Issue with custom SMTP server
Discussion in '3CX Phone System - General' started by gustavskii, Feb 15, 2018.
  1. gustavskii
    Jan 26, 2016
    63
    Hello after update we cannot connect to our SMTP server, and send emails
    Here is the issue:
    No compatible authentication mechanisms found.
    The were no changes made neither to the settings of 3cx (except update), nor to mail server, nor to firewall settings
  2. MichaelTC
    Jan 2, 2018
    I have the same issue, I went with a gmail work around until this gets fixed.
  3. accentlogic
    accentlogic New Member
    Nov 14, 2013
    181
    77
    We found this happened when SP2 was released and 3CX started enforcing TLS 1.2. That could be your issue, especially if you are using alternate ports. (Other than 465. Even 587 was an problem for them.)
  4. gustavskii
    Jan 26, 2016
    63
    Here is the error we get when we use TLS:
    Connection timed out: Ensure that Port 465 TCP is open for outbound traffic.
    #4 gustavskii, Feb 15, 2018
  5. gustavskii
    Jan 26, 2016
    63
    @accentlogic
    Thank you, you were right
    We were using 587 port, and our firewall didn`t have rule for 465
    As soon as we enabled 465 and set it as connection port, it started working
