Issue with extension.
Discussion in 'iOS' started by Reedl, Feb 27, 2013.
  1. Reedl
    Feb 27, 2013
    9
    Bit of an odd issue that I'm experiencing, any suggestions will be very much appreciated.
    Basically, I'm working remotely and every time I attempt to use my extension that I use with my desktop, my 3CX phone app will give me a forbidden message. Although, when I switch from that extension to different extension with the exact same settings, only the username, ID, and password are different, the app will work as intended.
    Any assistance is welcomed!
    Thanks.
    10,360
    226
    Each 3CX extension does have an option to allow/dis-allow remote registrations, and to restrict outside calls. I would compare the settings in the PBX, between the working and non working extension.
  3. StefanW
    Jun 2, 2009
    1,172
    76
    are you using a 3cx phone system (pbx)?
