Issue with IVR Service
Discussion in '3CX Phone System - General' started by jflood3, Oct 26, 2011.
  1. jflood3
    Oct 26, 2011
    I am new 3CX customer but happy with the product so far. I have a 3CXPSPRO on Version 10 with SP3 Build 21197 running on a Windows Server 2008 R2 in a VM environment.
    I have configured all of my extensions and provisioned my phones. Everything was working fine until last week when no one could access their voicemail. When I checked the System Services everything i working fine but he system extension status shows my special menu as non registered. I backed up the setting, uninstalled the 3CX server, rebooted, re installed using IIS with the backup and the same issue. I did the same process again but tried using the Abyss Server option but this did not solve it.
    I reviewed this with my reseller but he did not know what to do.
    Below is the log from the IVR. I see an error from the service "Error! Module '3CX.com.OSBinet'. Error ID 303."
    What does this error mean?
    23:04:38.824|3420|.\3CXIvrService.cpp(893):IvrService, main(), Starting service, revision 9.0.20931.0
    23:04:39.511|2480|.\3CXIvrService.cpp(600):IvrService, MainServiceProc::Run(), Loading configuration
    23:04:39.511|2480|.\ConfigLoader.cpp(100):IvrService, ConfigLoader::Load(), C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg
    23:04:39.511|2480|.\3CXIvrService.cpp(608):IvrService, MainServiceProc::Run(), Initializing VxmlCreator
    23:04:39.511|2480|.\IVR_Api.cpp(687):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    23:04:39.511|2480|.\3CXIvrService.cpp(664):IvrService, MainServiceProc::Run(), Setting IVR parameters
    23:04:39.511|2480|.\3CXIvrService.cpp(688):IvrService, MainServiceProc::Run(), Setting callback functions
    23:04:39.511|2480|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 9.0.20944.0
    23:04:39.511|2480|.\IVR_Api.cpp(313):IvrDll, IVRApi::Init(), Initializing sockets
    23:04:39.511|2480|.\IVR_Api.cpp(322):IvrDll, IVRApi::Init(), Initializing WWW library
    23:04:39.511|2480|.\IVR_Api.cpp(361):IvrDll, IVRApi::Init(), Loading configuration
    23:04:39.511|2480|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    23:04:39.511|2480|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5000/ivr/ivr_start.aspx'
    23:04:39.511|2480|.\IVR_Api.cpp(232):IvrDll, IVRApi::LoadConfiguration(), Prompts URL: 'http://localhost:5000/ivr/prompts'
    23:04:39.511|2480|.\IVR_Api.cpp(258):IvrDll, IVRApi::LoadConfiguration(), Using beep URI 'file:///C%7c/Program%20Files%20%28x86%29/3CX%20PhoneSystem/Bin/%2e%2e/Data/Ivr/Media/beep%2ewav'
    23:04:39.511|2480|.\IVR_Api.cpp(280):IvrDll, IVRApi::LoadConfiguration(), Using error message URI 'file:///C%7c/Program%20Files%20%28x86%29/3CX%20PhoneSystem/Bin/%2e%2e/Data/Ivr/Media/error%2ewav'
    23:04:39.511|2480|.\IVR_Api.cpp(298):IvrDll, IVRApi::LoadConfiguration(), Using inet cache dir 'C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cache'
    23:04:39.511|2480|.\IVR_Api.cpp(367):IvrDll, IVRApi::Init(), Initializing VXI platform
    23:04:39.511|2480|(0):Subtag VXIplatformInit. entering (log init complete): 0x01D734A0
    23:04:39.621|2340|(0):Error! Module '3CX.com.OSBinet'. Error ID 303.
    23:04:39.621|2480|(0):Subtag SBjsiInit. entering: 0x01D74BB0, 4000, 16384000, 131072, 100000
    23:04:39.621|2480|(0):Subtag SBjsiInit. exiting: returned 0
    23:04:39.636|2480|(0):Subtag VXIplatformInit. exiting: rc = 0
    23:04:39.636|2480|.\IVR_Api.cpp(376):IvrDll, IVRApi::Init(), State machine initializing
    23:04:39.636|2480|.\3CXIvrService.cpp(703):IvrService, MainServiceProc::Run(), Creating SL Agent
    23:04:39.636|2480|.\3CXIvrService.cpp(720):IvrService, MainServiceProc::Run(), Connecting to PBX (SL Agent)
    23:04:39.636|2480|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    23:04:39.902|2408|.\SLAgent.cpp(290):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    23:04:39.996|2408|.\SLAgent.cpp(146):IvrService, UpdateLines(), Component Settings:=====[0133EB30]
    CS=62914560
    IVRDIALINGTONE=
    MCFS=5242880
    MUSICONHOLDFILE=C:\ProgramData\3CX\Data\Ivr\Prompts\onhold.wav
    PBXSIPPORT=5060
    PROMPTPATH=C:\ProgramData\3CX\Data\Ivr\Prompts\Sets
    RECVA=0
    RECVIP=-1
    RECVP=0
    RTPFIRST=40610
    RTPLAST=40866
    SENDA=0
    SENDIP=-1
    SENDP=0
    SIP=40600
    SIPINTERFACE=10.0.1.39
    23:04:50.657|2408|.\PbxMedia\IVREngine.cpp(1597):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060500[][][EndCall,IVRForward,MakeCall,PlayFile,RecordFile]
    23:04:50.657|2408|.\PbxMedia\IVREngine.cpp(1613):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:500
    23:04:50.657|2408|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering EndCall helper
    23:04:50.657|2408|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering IVRForward helper
    23:04:50.657|2408|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering MakeCall helper
    23:04:50.658|2408|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering PlayFile helper
    23:04:50.658|2408|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering RecordFile helper
    23:04:50.658|2408|.\PbxMedia\IVREngine.cpp(1723):IvrService, IVREngine::RegisterLines(), Registering of lines done.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please restart 3CX PhoneSystem service and then check "Server Activity log" page in management console.
    Do you see any [EC......] messages in that log?
    Please wait some time after restart (around one minute) and then post startup log here (3CXPhoneSystem.log and 3CXPhoneSystem.trace.log)
  3. jflood3
    Oct 26, 2011
    Hi SY,
    Yes there are a few.
    12:28:47.330 Currently active calls [none]
    12:28:16.955 Currently active calls [none]
    12:27:55.302 [CM504001]: Ext.808: new contact is registered. Contact(s): [sip:808@127.0.0.1:5488/808]
    12:27:55.189 [CM504001]: Ext.803: new contact is registered. Contact(s): [sip:803@127.0.0.1:5488/803]
    12:27:54.279 [CM504004]: Registration succeeded for: 10001@Nextiva - 7325632220
    12:27:54.254 [CM504004]: Registration succeeded for: 10000@Nextiva
    12:27:54.231 [CM504004]: Registration succeeded for: 10003@Nextiva - 7323571300
    12:27:54.202 [CM504004]: Registration succeeded for: 10002@Nextiva - 7323571289
    12:27:54.042 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:704@127.0.0.1:40300;rinstance=037ec3703a60346a/704]
    12:27:54.041 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:703@127.0.0.1:40300;rinstance=2c406f1abaa503a1/703]
    12:27:54.040 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:702@127.0.0.1:40300;rinstance=64365d67a0e611bc/702]
    12:27:54.032 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:701@127.0.0.1:40300;rinstance=2117297a12f5a42e/701]
    12:27:54.016 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:700@127.0.0.1:40300;rinstance=73b7e034d82f6939/700]
    12:27:53.961 [CM504003]: Sent registration request for 10001@Nextiva - 7325632220
    12:27:53.940 [CM504003]: Sent registration request for 10000@Nextiva
    12:27:53.916 [CM504003]: Sent registration request for 10003@Nextiva - 7323571300
    12:27:53.891 [CM504003]: Sent registration request for 10002@Nextiva - 7323571289
    12:27:53.870 IP(s) added:[10.0.1.39]
    12:27:53.529 [CM504001]: Ext.SP9: new contact is registered. Contact(s): [sip:SP9@127.0.0.1:40000;rinstance=ae94e4f920050941/SP9]
    12:27:53.528 [CM504001]: Ext.SP8: new contact is registered. Contact(s): [sip:SP8@127.0.0.1:40000;rinstance=3c2d189d5ca5ebe5/SP8]
    12:27:53.527 [CM504001]: Ext.SP7: new contact is registered. Contact(s): [sip:SP7@127.0.0.1:40000;rinstance=f4d27f1f350e5ff3/SP7]
    12:27:53.524 [CM504001]: Ext.SP6: new contact is registered. Contact(s): [sip:SP6@127.0.0.1:40000;rinstance=fcfb24767ec93d3b/SP6]
    12:27:53.523 [CM504001]: Ext.SP5: new contact is registered. Contact(s): [sip:SP5@127.0.0.1:40000;rinstance=94ffaa533af12b44/SP5]
    12:27:53.521 [CM504001]: Ext.SP4: new contact is registered. Contact(s): [sip:SP4@127.0.0.1:40000;rinstance=a8fcd10e7fc0bf25/SP4]
    12:27:53.520 [CM504001]: Ext.SP3: new contact is registered. Contact(s): [sip:SP3@127.0.0.1:40000;rinstance=b89a875b05257d1b/SP3]
    12:27:53.518 [CM504001]: Ext.SP2: new contact is registered. Contact(s): [sip:SP2@127.0.0.1:40000;rinstance=1ec3a58b2b2fe04d/SP2]
    12:27:53.504 [CM504001]: Ext.SP1: new contact is registered. Contact(s): [sip:SP1@127.0.0.1:40000;rinstance=b67152e2d125180f/SP1]
    12:27:53.486 [CM504001]: Ext.SP0: new contact is registered. Contact(s): [sip:SP0@127.0.0.1:40000;rinstance=72cdcc6594d5d398/SP0]
    12:27:53.461 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=3931b10932441116/*1]
    12:27:53.444 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=5e93e333ec743897/*0]
    12:27:53.426 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000;rinstance=f997def568be5703/*777]
    12:27:50.319 [CM504001]: Ext.DialCode: new contact is registered. Contact(s): [sip:DialCode@127.0.0.1:5488/DialCode]
    12:27:49.604 [CM504001]: Ext.230: new contact is registered. Contact(s): [sip:230@127.0.0.1:61003;rinstance=91924281d7502b52/230]
    12:27:49.604 [CM504002]: Ext.230: a contact is unregistered. Contact(s): [sip:230@127.0.0.1:61003;rinstance=91924281d7502b52/230]
    12:27:48.551 [EC100007]: External application is connected: application:s29:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:49800
    12:27:48.433 [CM504004]: Registration succeeded for: 10000@Nextiva
    12:27:48.401 [CM504004]: Registration succeeded for: 10002@Nextiva - 7323571289
    12:27:47.833 [CM504004]: Registration succeeded for: 10001@Nextiva - 7325632220
    12:27:47.806 [CM504004]: Registration succeeded for: 10003@Nextiva - 7323571300
    12:27:47.617 [EC200002]: Media server is connected: application:s29:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:49797
    12:27:47.592 [CM504008]: Fax Service: registered as sip:888@10.0.1.39:5060 with contact sip:888@10.0.1.39:5100;user=phone
    12:27:47.313 [CM504003]: Sent registration request for 10002@Nextiva - 7323571289
    12:27:47.285 [CM504003]: Sent registration request for 10000@Nextiva
    12:27:47.255 [CM504003]: Sent registration request for 10003@Nextiva - 7323571300
    12:27:47.102 [CM504003]: Sent registration request for 10001@Nextiva - 7325632220
    12:27:46.736 [EC200005]: Parking Orbit server is connected: application:s29:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:49796
    12:27:46.736 Currently active calls [none]
    12:27:45.206 [EC200004]: IVR server is connected: application:s29:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:49795
    12:27:44.862 [EC200006]: Conference server is connected: application:s29:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:49791
    12:27:44.019 [CM506005]: Public IP=xxx.xxx.xxx.xxx is used for WAN communications through local interface with IP=10.0.1.39
    12:27:44.019 Transport [ V4 10.0.1.39:5060 UDP target domain=unspecified mFlowKey=776 ] is joined to SIP multicast group
    12:27:44.019 Failed to obtain short path name for [C:\ProgramData\3CX\Bin\Cert]
    12:27:44.019 [CM501006]: Default Local IP address: [10.0.1.39]
    12:27:44.019 [CM501002]: Version: 10.0.21196.0
    12:27:44.019 [CM501001]: Start 3CX PhoneSystem Call Manager
    12:27:44.019 [CM501009]: License Info: Loaded Succeeded
    12:27:43.847 [EC200001]: Configuration server is connected: application:s29:5485/DBProvider local:127.0.0.1:49788 remote:127.0.0.1:5485
    12:27:43.847 [CM501007]: *** Started Calls Controller thread ***
