Issue with Popup
Discussion in 'CRM / Helpdesk / App Integration' started by techdummy, Jan 2, 2018.
  1. techdummy
    techdummy New Member
    Sep 22, 2017
    139
    8
    We have created a CRM plugin as per the instructions provided in the below article.
    https://www.3cx.com/docs/crm-integration/
    The issue we are facing now is that, when a call comes in, the popup doesnt show the full number, instead it only shows the last 7 digits of the number.
    Is there anyway we can change this and show the complete number?
    Thank you.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi @techdummy,
    The 3CXPhone for Windows client notifies the entire caller number. It should be the plugin implementation which is filtering the last N digits... You need to check the code you created.
    Kind regards.
    Ernesto.
    techdummy likes this.
  3. techdummy
    Sep 22, 2017
    139
    8
    Thank you for the reply @edossantos
    It is not just the number, we are not able to see any details either once the popup comes.
  4. edossantos
    Jun 27, 2007
    1,080
    77
    Can you share a screenshot of what you see? You created a custom plugin for CRM integration?
  5. techdummy
    Sep 22, 2017
    139
    8
    Thank you but we have figured out the issue.
    In 3cx softphone,
    Advanced settings > Intergration > General > "Maximum digit length to compare", was set to default value of 7, and hence it was showing up only the last 7 digits or characters.
    We changed it to the required value and it works like a charm! :)
    Thanks everyone. Cheers!
