Issue with VOIP provider - incomming calls
Discussion in '3CX Phone System - General' started by south3, Sep 9, 2010.
  1. south3
    Aug 28, 2009
    15
    I have a problem with incoming calls from my VOIP-provider. They only occur when the provider routes calls from his own VOIP-customers, not "ordinary" PSTN calls. However, this seems to work when a 3CX customer calls a 3CX customer but not otherwise.
    I see nothing in my log, but the provider receives this message from my server;
    SIP MESSAGE 43 213.x.x.x:5060(sip3.xxxx.com) -> 91.xx.xx.xx:5060() UDP Frame 43 6/Sep/10 14:15:0.9116 TimeFromPreviousSipFrame=0.0001 TimeFromStart=866.7305 SIP/2.0 407 Proxy Authentication Required Via: SIP/2.0/UDP 91.90.24.141:5060;branch=z9hG4bK07090861;rport=5060 Proxy-Authenticate: Digest nonce="414d535c02956c5c44:556316fe5848e291d01c99f7deb84085",algorithm=MD5,realm="3CXPhoneSystem" To: <sip:08xxxxxxx@sip3.xxxxxx.se>;tag=21512a7f From: "040xxxxxx"<sip:040xxxxxx@sip3.xxxxx.se>;tag=as2920132c Call-ID: 78f148b133d0c4b77b3e36783c7dbc78@sip3.xxxxxx.se CSeq: 103 INVITE User-Agent: 3CXPhoneSystem 9.0.13677.0 Content-Length: 0
    So my server sends a 407-message to him when routing VOIP calls, but not otherwise. After that (and a lot more traffic) my server finally sends him SIP/2.0 401 Unauthorized
    I've examined another configuration of a 3CX v7 installation that works and I cannot find any differences that would explain this behaviour other than the version. This problem is not just for my installation.. I noticed that he's using different host names for the same IP, but it works when ordinary calls are coming in, so it shouldn't matter I suppose..
    Provider is set up as Generic VOIP provider (no outbound proxy defined).
    Any suggestions are welcome :p
    B.r
    Joakim
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
    hi,
    just like this but i'm not sure.
    try to active registration for incomming and outgoing calls. in voip line configuration
    i'm not sure.
  3. south3
    Aug 28, 2009
    15
    I've tried this (this was actually already set up that way).
    Got any more suggestions?
    B.r
    Joakim
