Issues after upgrading from V14 to V15
Discussion in 'CRM / Helpdesk / App Integration' started by sigma5, Jun 2, 2017.
  1. sigma5
    Dec 10, 2014
    The install itself went smoothly. I am now suffering the following issues -
    - Three times since the upgrade (1 week ago), all hard phones have lost audio when receiving/sending an external call. The fix is to restart services or run firewall check (which restarts services) Firewall checker passes with no errors. Internal calls never fail
    - Soft phone issue - The soft phone CTI mode will not connect to the hard phone and you cannot view call history/contacts/presence info in any mode. This can be fixed with resending the welcome email and reinstalling but I'm trying to avoid that. Strangely, 3 out of the 30 connected softphones have not lost any connectivity and continue to work.
    - Android and MAC mobile installs all stopped working but work after a reinstall
    - Error in log - 3cx error block WAN requests is on - But I cannot be sure that this event occurred at the same time as the outages
    Side info - Server is installed in Windows 2012 R2, a handful of patches were applied at the same time as the upgrade. Desktops are all Windows 10
    I have a feeling during install I may have selected to address phones by FQDN rather than IP but only a hunch. Would that cause these issues?
    Thoughts?
