issues with ack's and sip returning internal IP's, but not on my network
Discussion in '3CX Phone System - General' started by Brad Cann, Nov 10, 2017.
  1. Brad Cann
    Brad Cann New Member
    May 5, 2017
    109
    15
    Gday All,
    We have a 1800 number that our staff call, and have occasionally had issue with calls dropping out for no reason, looking at the 3cx activity log we saw some ack errors and lodged them with our Voice provider. (Attached as image), they cam back to us with their trace which shows the sip/2.0 200OK's referring to internal IP ranges, but not actually our internal IP Ranges, which are obviously causing the ACK's not to come back and the call to drop, as per below:
    Our External IP's are removed as well as the calling/recieving number:
    Please find the below 200 OK for both call sample:
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 125.213.160.83:5060;branch=z9hG4bK37dd5a053llbf7b7INV6ab3726b2c9
    Contact: <sip:XXXXXX@127.0.0.1:5060>
    To: <sip:XXXXX@58.XXX.XXX.19;user=phone>;tag=1e54c53f
    From: "XXXXXX"<sip:XXXXXX@125.213.160.83;user=phone;noa=national>;tag=6ab3726b-co713-INS003
    Call-ID: ac50f2-128d-1010201733544-bn04-esy1-1-59.86.190.66
    CSeq: 71301 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
    Content-Type: application/sdp
    Supported: replaces, timer
    User-Agent: 3CXPhoneSystem 15.5.3849.1 (3392)
    Content-Length: 297
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 125.XXX.XXX.83:5060;branch=z9hG4bK37dd5a053ll168abfINV1f803a6453f
    Contact: <sip:XXXXXXX@1.1.1.1:5060>
    To: <sip:XXXXXXX@58.XXX.XXX.19;user=phone>;tag=1650731f
    From: "XXXXX"<sip:XXXXXX@125.213.160.83;user=phone;noa=national>;tag=1f803a64-co1343-INS003
    Call-ID: ac1119-14b1-1010201724613-bn03-esy1-0-59.86.190.65
    CSeq: 134301 INVITE
    Content-Length: 297
    Where on earth are the 1.1.1.1:5060 and internal loopback 127.0.0.1:5060 coming from??
      File size:
      28.2 KB
      6
    #1 Brad Cann, Nov 10, 2017
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,323
    72
    127.0.0.1 I have seen before, 1.1.1.1 never....
    The first thing I must ask is, is this a 3CX-approved provider? If not, I would highly recommend testing with an approved one first. There are a few you can use and signup online, and some even give you a free number to play with, like CallCentric.
    If nothing else, this should help you understand if it is something relating to the specific provider and/or settings or not.
    Now other things you can check is:
    • In the SIP Trunk settings --> DIDs tab, are the DID number entered in a short format? E.g. *158? If so make them at least 7 digits long, e.g. *123456. Warning, you may have to recreate the Inbound Rules after modifying the numbers.
    • In the SIP Trunk settings --> Options tab, check that you have to set to use a specific IP.
    • In Settings --> Network, check that you have entered the correct Public IP address.
    Edit: On second thought, I have seen 1.1.1.1 once, when for some reason someone was trying to have 3CX recognize a SIP Trunk but using the "Bridge" option...
  3. Brad Cann
    May 5, 2017
    109
    15
    This is our OWN internal 3cx install.
    1. Sip trunk DID's are full length numbers
    2. Which specific IP as i could see 2 places you could be talking about: either Put public IP in sip VIA heading, or select which IP to use in Contact and connection fields?
    3. Correct Public IP is in place.
    Edit: I can't see the "Bridge option" anywhere??
  4. NickD_3CX
    Jun 2, 2014
    1,323
    72
    Both, but mainly in the "select which IP to use in Contact and connection fields" option, what setting do you have there?
  5. Brad Cann
    May 5, 2017
    109
    15
    Default settings.
  6. NickD_3CX
    Jun 2, 2014
    1,323
    72
    I sent you a PM.
  7. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    What was the outcome of this?
    PS: We used to use CallCentric until a flood in New York City knocked them offline for days and they would not return our calls or messages. Our business was adversely affected. They never followed up.
  8. NickD_3CX
    Jun 2, 2014
    1,323
    72
    Just to be clear, I only suggested using CallCentric as a test as they:
    a) Are a supported provider
    b) They offer the ability to make an account for free and make test calls to/from other free CallCentric accounts.
    At this point we would need to check the log files to see what is causing this.
  9. Bob Denny
    Feb 21, 2009
    131
    I guess I should apologize. Sorry! It was off-topic for this issue anyway :-(
  10. Brad Cann
    May 5, 2017
    109
    15
    Thats fine, we self host, as the cost of the program is peanuts compared to what a hardware based PBX costs here in australia, and also compared to what a "Managed" PBX costs often <12 months payback.
