Issues with extension web portal access denied. on Windows 7
Discussion in '3CX Phone System - General' started by karl800, May 23, 2010.
  1. karl800
    May 21, 2010
    13
    Hi All,
    Had an issue this morning thought to share out the fix if any one else comes across this.
    Server is installed on Windows 7 Machine, and testing on local server too. Not sure if this problem will still happen remotely.
    I was trying to login extension web portal http://localhost:5000 and was getting access denied from the web server, 3CX web server not IIS.
    Seemed like i needed to take ownership of folder located C:\ProgramData\3CX\Data\Http\Interface
    There was a padlock showing, so needed give rights to one of the folders in there. Sorry i can't remmeber the exact folder now, But it does show in your web browser when you get the access denied message.
