Issues with IP Trunk
Discussion in '3CX Phone System - General' started by celtic, Feb 5, 2011.
  1. celtic
    Dec 16, 2010
    Hi Guys
    I have a Sip trunk that authenticates via IP address, I believe i have set this up correct in 3CX but when i try and make a outgoing call i get server failuire
    Below is what i have been sent from my provider
    Inbound numbers : 0288297xxxx
    Number of Channel(s) : 2
    Customer IP address : 77.xxx.xxx.xx
    SIP trunk name : TRUNK_OVCEL001_01
    Please send all outbound calls to 77.107.128.156. All inbound calls will be received from 77.107.128.156 as well.
    There’s no username and password for this SIP Trunk as inbound and outbound calls use the IP address provided to route calls.
    Calls will be sent to your switch in E164 number format (e.g. +44).
    Below is the Log file
    08:55:59.435 [CM503020]: Normal call termination. Reason: Server Failure
    08:55:59.435 [CM503016]: Call(22): Attempt to reach <sip:901656864145@192.168.1.100:5060> failed. Reason: Server Failure
    08:55:59.434 [CM503003]: Call(22): Call to sip:01656864145@77.107.128.156 :5060 has failed; Cause: 503 Service Unavailable; warning: ; internal
    08:55:59.384 [CM503025]: Call(22): Calling VoIPline:01656864145@(Ln.10000@O-bit)@[Dev:sip:02882977027@77.107.128.156 :5060]
    08:55:59.208 [CM503004]: Call(22): Route 1: VoIPline:01656864145@(Ln.10000@O-bit)@[Dev:sip:02882977027@77.107.128.156 :5060]
    08:55:59.205 [CM503010]: Making route(s) to <sip:901656864145@192.168.1.100:5060>
    08:55:59.202 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:100@192.168.1.100:5060]
    08:55:59.199 [CM503001]: Call(22): Incoming call from Ext.100 to <sip:901656864145@192.168.1.100:5060>
    08:54:58.473 [CM503020]: Normal call termination. Reason: Server Failure
    08:54:58.473 [CM503016]: Call(21): Attempt to reach <sip:901656864145@192.168.1.100:5060> failed. Reason: Server Failure
    08:54:58.472 [CM503003]: Call(21): Call to sip:01656864145@77.107.128.156 :5060 has failed; Cause: 503 Service Unavailable; warning: ; internal
    08:54:58.372 [CM503025]: Call(21): Calling VoIPline:01656864145@(Ln.10000@O-bit)@[Dev:sip:02882977027@77.107.128.156 :5060]
    08:54:58.199 [CM503004]: Call(21): Route 1: VoIPline:01656864145@(Ln.10000@O-bit)@[Dev:sip:02882977027@77.107.128.156 :5060]
    08:54:58.180 [CM503010]: Making route(s) to <sip:901656864145@192.168.1.100:5060>
    08:54:58.178 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:100@192.168.1.100:5060]
    08:54:58.172 [CM503001]: Call(21): Incoming call from Ext.100 to <sip:901656864145@192.168.1.100:5060>
    08:54:14.781 [CM503020]: Normal call termination. Reason: Not found
    08:54:14.781 [CM503016]: Call(20): Attempt to reach <sip:01656864145@192.168.1.100:5060> failed. Reason: Not Found
    08:54:14.781 [CM503014]: Call(20): No known route to target: <sip:01656864145@192.168.1.100:5060>
    08:54:14.780 [CM503010]: Making route(s) to <sip:01656864145@192.168.1.100:5060>
    08:54:14.779 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:100@192.168.1.100:5060]
    08:54:14.774 [CM503001]: Call(20): Incoming call from Ext.100 to <sip:01656864145@192.168.1.100:5060>
    hope you can help
    rob
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    just a guess, but by any chance, have you entered your public IP address as the VoIP Providers "Sip Host Address"?
    if you have, please change this to the VoIP Providers host address.
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    You dont have an outbound rule set up.
    3cx does not know the difference in theory between an internal sip call and external sip call - it just looks up routes. if you dial an internal extension it looks up that extension and sees it is there and routes the call. If you dial an external number it looks up its outbound rules for a matching route.
    People think there is a "default" route but there isnt. There has to be an outbound rule set up. You can easily set it up for all calls and it will work. Your logs showed there are no matching outbound rules set up for the number you dialed.
