Solved It has probably been answered .. Picking up VM from another extension
Discussion in '3CX Phone System - General' started by jono659, Aug 7, 2017.
  1. jono659
    Aug 7, 2017
    Searched and looked through forums but can't seem to find this. When dialling my voice mail menu extension (666 in my case) and ignore the enter pin Number message, I was under the impression that I should get the chance to dial an extension to tend to Voicemail on that extension. All I get is the message invalid pin number then please enter personal identification number repeatedly.
    Sorry for being a noob, have spent the whole morning in the phone system management but to no avail. Anyone have a clue?
    Many thanks in advance.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @jono659
    When you dial 666, as soon as the call is connected, press # (hash).
    You will be prompted to enter the extension number, then the vm pin.
  3. jono659
    Aug 7, 2017
    Haha, feeling like a bit of a ding now. Many thanks for your prompt reply.
  4. Panayiotis_3CX
    Apr 26, 2017
    165
    7
