It is possible to use pjsip to connect to a 3CX Phone System over the 3CX tunnel?
Discussion in '3CX Phone System - General' started by sarahjoh, Feb 23, 2018.
Tags:
  1. sarahjoh
    Feb 23, 2018
    Hello All, Hope All doing good.
    I will split the question in some sub questions:
    Is the 3CX tunnel a true TCP SIP proxy?
    It is possible to use the pjsip to connect to it?
    How should I set up the account and connection data if this is possible?
    Let's consider the 3CX server is running behind the NAT and the public IP address is: 123.123.123.123, tunnel is working on port 5090 and the internal address of the 3CX is 192.168.1.13. the SIP user is user1@123.123.123.123 with pass: userPass and the tunnel has the password tunnelPass.
    https://www.bloomberg.com/research/stocks/private/snapshot.asp?privcapId=2507312 | Azure
    How should the pjsip account structure be initialized?
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,255
    203
    I very much doubt you will be able to connect to the 3CX tunnel except using 3CX applications, 3CX own protocol.
