- Joined
- May 3, 2007
- Messages
- 7
- Reaction score
- 0
Henk,
I noticed on a forum message, that you're going to write up a manual with respect to the spa3102. I am also using it, and have a few different settings than your website. If it will help , I can send you a zipped package of all the config screenshots. I opted for a vpn login rather than fight ports/firewall on all external extensions.
I also managed to get the vpn login working for Ubuntu linux with a sjphone extension installed.
So if you want to add info for linux, I can send config screenshots as well.
Thanks for your original config info.
Cheers
deGuile
Cheers
deGuile
