It's possible to send sms between internals?
Discussion in '3CX Phone System - General' started by gmcompu, Apr 13, 2012.
  1. gmcompu
    Apr 13, 2012
    Hi friends, i install 3cx and have it owrking in minutes, i can make free calls outside the lan without problems.
    I would like to know if there's a chance to send sms between terminals, these would be great!
    Thank you for your answers!
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    3CX does not support SMS messages
  3. gmcompu
    Apr 13, 2012
    KerryG
    Thank you very much for your answer!
  4. willow
    willow Member
    Mar 1, 2011
    471
    you can do it with phones that support it. I know the yealinks support it. you could also chat with my phone if a computer is available.
  5. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi Myphone system works great..
