ITSP just doesnt work with the system any longer.
Discussion in '3CX Phone System - General' started by giovanni0826, Jun 29, 2007.
  1. giovanni0826
    Apr 6, 2007
    53
    one of the providers i've been using all a sudden doesn't work properly through the 3cx. no upgrades have been done, no system changes have been completed recently. the provider is VArphonex. this is the issue; incoming calls connect through the 3cx to DR to extension just fine but after 20 or so seconds the call is disconnected. this is the message when it happens.
    13:04:13.203 StratLink::eek:nHangUp [CM104001] Call(7): Ln:10000@VAR hung up call; cause: unknown
    outbound calls are no problem. they complete and stay up.
    the service provider works properly both ways when configured with a softphone.
    this is a call log of a failure.
    13:16:13.343 StratLink::eek:nHangUp [CM104001] Call(8): Ln:10000@VAR hung up call; cause: unknown
    13:15:54.765 CallLegImpl::eek:nConnected [CM103001] Call(8): Created audio channel for Ext.1100 (192.168.2.253:8186) with Media Server (192.168.2.1:7008)
    13:15:54.765 StratInOut::eek:nConnected [CM104005] Call(8): Setup completed for call from Ln:10000@VAR to Ext.1100
    13:15:54.125 CallConf::eek:nProvisional [CM103003] Call(8): Ext.1100 is ringing
    13:15:50.312 MediaServerReporting::DTMFhandler [MS211000] Call(8) Ln:10000@VAR: DTMF (RTP) from 208.239.76.163:59162 arrived. in-band DTMF tone detection is turned off.
    13:15:41.250 CallLegImpl::eek:nConnected [CM103001] Call(8): Created audio channel for Ln:10000@VAR (208.239.76.163:59162) with Media Server (my.public.ip:9008)
    13:15:41.234 CallConf::eek:nIncoming [CM103002] Call(8): Incoming call from 954585xxxx (Ln:10000@VAR) to sip:7878878-3cgnm33qd7a7d@10.0.5.63
    varphonex support isn't any help. does any have a clue what the issue.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Just describe VoIP provider option configured in PBX.
    Thanks,
    Stepan
