IVR allowing to choose an extension manually, is it possible
Discussion in '3CX Phone System - General' started by 3cxisti, Jan 15, 2013.
  1. 3cxisti
    Dec 11, 2012
    25
    it was possible on our old asterisk-based system to allow the caller to enter the extension manually and he was lead to this one.
    I would like to let the caller hear a musik and allow him / her to choose the extension needed.
    Is it possible with 3CX?
    Thank you.
    I.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Re: IVR allowing to choose an extension manually, is it poss
    By default when you hear IVR you can press the extension number and your call will be automatically transfered to that extension...
