IVR Answer on X number of rings?
Discussion in '3CX Phone System - General' started by Quenten Grasso, Oct 1, 2017.
  1. Quenten Grasso
    Sep 28, 2017
    Hi All,
    Does anyone know if its possible to adjust the IVR to answer on say 2 rings instead of instantly?
    Thanks,
    Quenten
    10,356
    224
    You may have to "route" though an extension set to forward off the call after a given time (the length of two rings, if desired). As you want the extension to actually ring (twice), and not immediately forward to the IVR, it would (unfortunately) have to be a registered device.
  3. accentlogic
    accentlogic New Member
    Nov 14, 2013
    160
    66
    You can route the calls to a Ring Group, and the Destination if no answer would be your IVR. We use this often for Incoming Calls so that a Ring Group (even if it's just the Receptionist/Operator extension) has a chance to answer calls before it goes to the Open Digital Receptionist.
  4. the60
    the60 New Member
    Oct 21, 2011
    117
    50
    Create a dummy IVR.
    For recording, use the USProgresstone.wav file that comes with 3CX.
    Under "Destination for no or invalid input", define the number of seconds you want the IVR to play the progresstone for.
    Then route the call to the desired destination.
