IVR audio stopped.
Discussion in '3CX Phone System - General' started by derval, Feb 7, 2018.
  1. derval
    Jul 9, 2011
    my 3cx install was working fine and suddenly the IVR audio stopped.
    the system functions otherwise .. any advise
    note also i have restored a working backup and still the same effect
    PS i am running the latest 3cx
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @derval
    Are you referring to the IVR service or you mean that you cannot hear the prompt when in the IVR?
  3. derval
    Jul 9, 2011
    • Yes , none of the IVR recordings worked .. even the hold music..
    • I reloaded an old back up from earlier in Feb and the same thing.
    after updating the system prompts I noticed the IVR recording where all gawn (space empty under the IVR menu.)
    so I have relocated the welcome greeting so far and it works again so I am now going to load back all the music on hold and stuff.
