IVR digital receptionist
Discussion in '3CX Phone System - General' started by Andy Veal, Nov 6, 2017.
  1. Andy Veal
    Oct 5, 2017
    60
    We have an issue with customer's dialing * on the digital receptionist menu and this is being routed to a specific persons extension.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    77
    Although I can't know what is happening, I have a suspicion that something else might be going on because the accepted characters as defined by the parameter "IVR_DIRECT_DIALING_GRAMMAR" only allow digits 0-9, so * should be ignored all together.
    Could it be that they are also pressing other digits as well? I would suggest capturing an instance of this and check what rtpevent messages are being sent. Additionally if you check the 3CXIVR.log file, there you can also see what DTMF tones 3CX recognized. These 2 together should give you a good idea what is happening.
