IVR Extension Mishandling
Discussion in '3CX Phone System - General' started by robhicks, Mar 4, 2008.
  1. robhicks
    Feb 18, 2008
    8
    We're having some problems with incoming calls that attach to an IVR and then enter extension. The entries are being misread and routing is not happening correctly. For example, a caller may want to transfer to extension 117 and they enter 117 but end up at extension 111.
    The server log shows a potential DTMF error:
    C:341.1: 64.158.162.71:9648 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment
    Any help on how to fix this would be great.
    Thanks!
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Check that you 3CX box is configured for DTMF RFC2833. You IP-telephones on both sides and 3CX extensions must work with same DTMF RFC2833 method.
  3. robhicks
    Feb 18, 2008
    8
    Igor,
    Thanks for the response.
    We're using a SIP trunk from BroadVox. I've asked them how they are handling DTMF signaling. Is there anything that I can do within the PBX to look at or adjust how DTMF tones are being handled between the PBX and the SIP trunk?
    Thanks again for your help.
    Rob
