IVR inputs work intermittently
Discussion in '3CX Phone System - General' started by computing2, Mar 12, 2018.
  1. computing2
    Sep 25, 2015
    10
    We have AT&T IPFLEX running on 3CX V14 Service Pack 3. Since last week incoming calls are answered by IVR but intermittently the IVR inputs/options are not recognized. Any idea what is going on?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @computing2
    You may need to run a wireshark capture on the PBX and see if you are receiving the DTFMs. Filter the capture with rtpevent filter to see if the provider is sending them. If not, you may need to speak with the provider for this.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,449
    541
    You should also consider upgrading to V15.5 as V14 is no longer supported so you can receive the latest updates and fixes.
  4. computing2
    Sep 25, 2015
    10
    I ran wireshark on the PBX with rtpevent filter. I did not see any DTFMs in the captured log! Am I looking at it correctly? Would you be able to take a look at the log for me?
  5. computing2
    Sep 25, 2015
    10
    Here is the screenshot from wireshark with rtpevent filter. It appears that most of the transmission carried Inband DTMF are being ignored! What's the next step?
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Every line there is a DTMF...
    What happened last week? Perhaps provider made a change.
    Have you tried rebooting as a first fix?
  7. computing2
    Sep 25, 2015
    10
    Hi Craig, YES I have rebooted the application and the server many many time to no avail! No changes have been made to 3CX or anything on our side of the AT&T's router. Last week, AT&T had disconnected the circuits due to a financial dispute. All issues started once the reinstated the SIP circuit! They claim that nothing was been changed from their end, but something must have changed somewhere! Therefore, I am troubleshooting the issue by eliminating the potential problem sources. Do you have any thoughts as to why 3CX is recognizing the DTMFs? It seems 3CX intermittently catches 1-2 DTMFs and then ignore the others! Please Help!
  8. craigreilly
    Feb 1, 2012
    3,575
    305
    Have you restarted the SIP hardware (router?) Rerun firewall check since service reinstated?
    Grasping at straws here.
  9. computing2
    Sep 25, 2015
    10
    Hi Craig, Yes, all routers have been restarted since reinstatement of the services! Believe me, I have been in this situation for over a week now! I can use all the help I can get!
  10. craigreilly
    Feb 1, 2012
    3,575
    305
    what happens if you call the IVR internally - does the issue completely resolve?
  11. computing2
    Sep 25, 2015
    10
    Craig, Please pardon my ignorance, but how does one call the IVR internally? I have always accessed it from the main number?
  12. craigreilly
    Feb 1, 2012
    3,575
    305
    what is the IVR Extension?
  13. computing2
    Sep 25, 2015
    10
    Craig, It works internally without an issue!
  14. craigreilly
    Feb 1, 2012
    3,575
    305
    So likely 3cx itself is not the culprit.
    Now onto
    a) Provider/Provider Eqpt
    b) Provider Setup (within 3cx)
    c) The caller side -- assuming you have tried from different providers during testing? (different cell provider, landline provide, etc)
