IVR not working - "This call could not be completed"
Discussion in '3CX Phone System - General' started by lucasmuradrc, Jul 25, 2016.
  1. lucasmuradrc
    Jul 25, 2016
    6
    I'm having the following problem:
    - when i transfer the call to the satisfaction survey (an ivr), sometimes it returns a voice saying: " This call could not be completed. Please try again latter. We apologize."
    I tried everything, but i couldn't find what's causing the problem.
    The thing gets worse when i go to the manage board e the record in there it's ok, but when i played it, it returns the same voice saying: This call could not be completed. Please try again latter. We apologize."...
    What could be happening?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    The first thing to help is to know what version of 3CX you are running and how many calls it supports. The next thing is to provide the call flow to include what the IVR selection is supposed to do with regard to the survey aspect.
  3. lucasmuradrc
    Jul 25, 2016
    6
    Hello, lneblett!
    Thanks for the fast answer!
    Well, the version i have is the 14.0.49169.0, and it can support 32 sim calls.
    This is the call flow:
    - the agent treats the problem of the client, and in the end he/she transfer the client to the survey;
    - there, the client can answer if he had his problem solved;
    - than he will answer if he was well treated.
    This is how it is structured:
    Survey - digital receptionist 8006
    First question: 0 If no, digital receptionist 8007; 1 If yes, digital receptionist 8008;
    Second question if the first answer is no: 0 If no, digital receptionist 8009 that will connect with the queue 8014; 1 If yes, digital receptionist 8011 that will connect with the queue 8015.
    Second question if the first answer is yes: 0 If no, digital receptionist 8012 that will connect with the queue 8016; 1 If yes, digital receptionist 8013 that will connect with the queue 8017.
    We
  4. leejor
    10,360
    226
    If you are able to duplicate the failure, do so, then immediately check the 3CX Server Activity Log. it will show what happened to the call. You can click on verbose, at the top, for a lot more details.
  5. lucasmuradrc
    Jul 25, 2016
    6
    Where would be the verbose button?
    I'm trying to find, but i'm not able to.
  6. lucasmuradrc
    Jul 25, 2016
    6
    One thing that i discovered now: when the survey returns with this message, all the others digital receptionist returns with this too.
  7. leejor
    10,360
    226
    Above the log, there should be a "tick box" for Verbose
  8. lucasmuradrc
    Jul 25, 2016
    6
  9. lucasmuradrc
    Jul 25, 2016
    6
  10. leejor
    10,360
    226
    Did you have a look at the log, in particular, the point where the call(s) fail? If you aren't sure about what it is telling you, then post it here.
