IVR on Windows XP with 2 Network adapter does not work
Discussion in '3CX Phone System - General' started by awcalien8, Jan 29, 2008.
  1. awcalien8
    Jan 29, 2008
    6
    I have Instaled a second network and after this, the IVR does not work anymore.
    In the server monitor have log this message "IVR NOT FOUND"
    Somebody Help me!!!
    Can I use 3cx + windows XP connection sharing?
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    242
    3CX have to find the IVR. He lost it because you changed the network adapters. The old details are still in the DB I think so maybe the most simple way is to uninstall and reinstall 3CX in the "new" environment instead of letting it work with different network adapters. Do a clean install with the backup and see if things change. When you use different subnets, you can read in the technical manual how to configure that
  3. awcalien8
    Jan 29, 2008
    6
    I have fixed.
    The problem is the APACHE server.
    I can´t change the default listen port.
    Tanks
  4. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i have a ??? why do you need 2 nics???
  5. awcalien8
    Jan 29, 2008
    6
    Because I need:
    Router (Lan + Wan) Interface
    Storage Server
    IPBX
    In the same machine running in a windows XP professional
