IVR Options not working on incoming calls
Discussion in '3CX Phone System - General' started by aharley, Dec 6, 2011.
  1. aharley
    Dec 6, 2011
    When someone calls my main number, the IVR picks up correctly, but it does not respond to any selections (ivr menu options, extensions, etc.) being entered by the caller. I have updated to the latest service pack, thinking that would help resolve my issue, but it did not. Any assistance would be greatly appreciated.
    Here is a copy of my 3CXIvrServer log:
    2011/12/06 >>
    09:00:10.731|3048|.\3CXIvrService.cpp(893):IvrService, main(), Starting service, revision 9.0.20931.0
    09:00:10.747|2468|.\ConfigLoader.cpp(100):IvrService, ConfigLoader::Load(), C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg
    09:00:10.778|2468|.\IVR_Api.cpp(687):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    09:00:10.778|2468|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 9.0.20944.0
    09:00:10.950|2468|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    09:00:10.996|2468|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5000/ivr/ivr_start.aspx'
    09:00:11.277|2508|(0):Error! Module '3CX.com.OSBinet'. Error ID 303.
    09:00:11.340|2468|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    09:00:11.371|2600|.\SLAgent.cpp(290):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    09:00:32.111|2600|.\PbxMedia\IVREngine.cpp(1597):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:5060999[800][][EndCall,IVRForward,MakeCall,PlayFile,RecordFile]
    09:00:32.111|2600|.\PbxMedia\IVREngine.cpp(1613):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:999
    09:00:32.245|2600|.\PbxMedia\IVREngine.cpp(1654):IvrService, IVREngine::RegisterLines(), Registering IVR:800
    09:00:32.245|2600|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering EndCall helper
    09:00:32.245|2600|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering IVRForward helper
    09:00:32.245|2600|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering MakeCall helper
    09:00:32.246|2600|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering PlayFile helper
    09:00:32.246|2600|.\PbxMedia\IVREngine.cpp(1701):IvrService, IVREngine::RegisterLines(), Registering RecordFile helper
    09:00:32.246|2600|.\PbxMedia\IVREngine.cpp(1723):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    09:01:16.268|1068|(0):Error! Module '3CX.com.OSBinet'. Error ID 301. urlhttp://localhost:5000/ivr/(S(svfzzywbuztd3ogu3ndqus3x))/root.vxml
    09:01:16.644|1068|(0):Error! Module '3CX.com.OSBinet'. Error ID 301. urlhttp://localhost:5000/ivr/(S(svfzzywbuztd3ogu3ndqus3x))/root.vxml
    09:01:26.121|4436|(0):Error! Module '3CX.com.OSBinet'. Error ID 301. urlhttp://localhost:5000/ivr/(S(br4rkkp4m0rjadlpzdnyf3o0))/root.vxml
    09:01:26.194|4436|(0):Error! Module '3CX.com.OSBinet'. Error ID 301. urlhttp://localhost:5000/ivr/(S(br4rkkp4m0rjadlpzdnyf3o0))/root.vxml
    09:07:46.885|2168|(0):Error! Module '3CX.com.OSBinet'. Error ID 301. urlhttp://localhost:5000/ivr/(S(yyj00mxkiubgx5zxuqnvktju))/root.vxml
    09:07:46.959|2168|(0):Error! Module '3CX.com.OSBinet'. Error ID 301. urlhttp://localhost:5000/ivr/(S(yyj00mxkiubgx5zxuqnvktju))/root.vxml
  2. aharley
    Dec 6, 2011
    I deleted the Digital Receptionist and recreated it. This fixed my issue.
