IVR -- PbxAPI.aspx returns error
Discussion in '3CX Phone System - General' started by dbergsma, Jan 7, 2009.
  1. dbergsma
    Oct 27, 2008
    39
    Hi, by my understanding of a number of recent posts including http://www.3cx.com/forums/api-commands-for-version-7-not-working-8431.html
    Using IE to http://192.168.1.33:5484/PbxAPI.aspx?func=make_call&from=211&to=221&pin=211
    should cause ext #211 to phone #221.
    However, I receive an error
    TCX.PBXAPI.OperationFailed at TCX.PBXAPI.PBXConnection.MakeCall(String dn_from, String number_to) at Utils.MakeCall(NameValueCollection paramz)
    It looks like this is the same error as I receive when using the softphone in desktop mode (its a little hard to read in the little window).
    Prior to this -- I opened port #5484 on the server in windows firewall which started producing the error message -- otherwise I was receiving page not found.
    Thanks in advance.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    This is because the PBX is not licensed. Activate the PBX with a demo key for example and you will be able to make a call -
    After you make the call you should see
    Successful make call from X TO X
    We will arrange the notification with the next release - in the coming days.
  3. dbergsma
    Oct 27, 2008
    39
    thanks.
    You're right - a more useful explanation would help.
    cheers
    dean.
  4. robertkuhn
    Oct 23, 2014
    Hello I have the same error with a Version 12 Pbx an an active Demo Licence.
    can anyone help me.
    best regards
