IVR prompt message is cut short after 10 sec (Resolved)
Discussion in '3CX Phone System - General' started by dohabandit, Aug 26, 2010.
  1. dohabandit
    Jul 31, 2010
    5
    I have a problem that occurs on calls from my PSTN (using a SPA3102). When the call connects to the IVR, the prompt plays for only about 10 seconds or less and then the prompt repeats. I found this entry in the IVR logs that seems to indicate the IVR detected a DTMF * being pressed. Needless to say, no * was pressed.
    Is this a bug or something to do with DTMF detection in the SPA3102?
    23:49:21.045|5524|.\api\VXIpromptImpl.cpp(132):IvrDll, VXIpromptImpl::Impl::Queue(), baseUrl = 'http://localhost:5481/ivr/(S(qwal0d45ycqgi2uzmtq3rcyt))/root.vxml'
    23:49:21.045|5524|.\api\VXIpromptImpl.cpp(240):IvrDll, VXIpromptImpl::Impl::Queue(), Queuing AUDIO: C:\ProgramData\3CX\Data\Ivr\Prompts\Zoe2.wav
    23:49:21.045|5524|.\api\VXIrecImpl.cpp(304):IvrDll, VXIrecImpl::Impl::Recognize(), Recognition started
    23:49:32.304|3800|.\VXIMachine.cpp(1302):IvrDll, CallSession::DtmfPressed(), PBX/Media: Dtmf '*' pressed
    23:49:34.304|5524|.\api\VXIrecImpl.cpp(428):IvrDll, VXIrecImpl::Impl::Recognize(), Recognition stopped
    23:49:34.304|5524|(0):Subtag SBjsiEval. entering: 0x01CB3C70, 'application.waveform$ = null;', 0x00000000
    23:49:34.304|5524|(0):Subtag SBjsiEval. exiting: returned 0, 0x00000000 (0x00000000)
    23:49:34.304|5524|(0):Subtag SBjsiPushScope. entering: 0x01CB3C70, '$_execAnonymous_'
    23:49:34.304|5524|(0):Subtag SBjsiPushScope. exiting: returned 0
    SPA3102 settings for DTMF are (defaults I believe) :
    DTMF Process INFO: Yes
    DTMF Process AVT: Yes
    DTMF Tx Method: Auto
    DTMF Tx Mode: Strict
    DTMF Tx Strict Hold Off Time: 40
  2. dohabandit
    Jul 31, 2010
    5
    Re: IVR prompt message is cut short after about 10 seconds
    I changed the SPA3102 DTMF Tx setting to "Inband+Info" and this seems to have corrected the issue.
