IVR question
Discussion in '3CX Phone System - General' started by inteq, Jan 9, 2013.
  1. inteq
    Jan 8, 2013
    42
    Hello there
    I have a small question about the Digital Receptionist - IVR system in 3CX Phone System
    What I want to do
    Someone calls
    The call is routed to an IVR
    The IVR picks up the call and plays some music or some spoken information
    After 5 seconds (timeout) I want to redirect the call to an extension.
    No need for any input from the caller
    What I did
    Setup a rule for incoming.
    The rule is setup to play onhold.wav
    No menu options.
    After 5 seconds of timeout "Connect to extension XX"
    Non-existing extension "Repeat prompt"
    What is not working
    The call is picked up by the IVR and the onhold.wav is being played.
    The call does not get redirected to the desired extension after 5 seconds, but keeps on playing the onhold.wav.
    If I set the incoming rule to route the call to the same extension without any IVR, it works (the extension is ringing)
    Am I doing something wrong here? Or the above logic should work?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Not sure. You did not state the exact method for the rule.
    On an inbound call, you establish the rule that directs the call to an IVR. The IVR has a recording associated to it after which the caller response is expected. as the IVR has no keys set, the caller gets to the timeout and then gets directed to the location specified in the no response area.
    You should be able to dial the system extension for that IVR directly and see what happens.
