Solved IVR selection problem on DTMF caller input!
Discussion in '3CX Phone System - General' started by mic.max, Oct 27, 2017.
  1. mic.max
    Nov 24, 2010
    56
    I've installed 3cx ver. 15.5 SP1 with two digit extention configuration, i also configued five IVR this is the scenario:
    IVR1:
    digit 1 connect to IVR2
    digit 2 connect to IVR3
    digit 3 connect to IVR4
    digit 4 connect to extension 18
    digit 5 connect to extension 19
    when caller is connected to IVR1 and accidentally press twice 1 (11) or (12) or (22) the call are send to extension 11 or 12 or 22. Why ????????
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,080
    159
    Hi mic.max,
    This is by design, normally in an IVR environment you can, as part of the recording say "if you know your parties extension please dial it now" which then transfers you to an individuals local extension number. This is what is happening.
    That being said I would not recommend the use of 2 digit extension numbers anyway - this will give you a limited amount of extension numbers of which can not be altered when set. If your customer expands beyond the limit at anytime you could find yourself with an issue.
    YiannisH_3CX likes this.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    In Settings | Parameters edit IVR_DIRECT_DIALING_GRAMMAR to [0-9][1]
    It will fix your issue.
    Also you may use parameter IVRDONOTCALL to set list of extensions not to be called, like 00-99
    #3 sip.bg, Oct 28, 2017
  4. mic.max
    Nov 24, 2010
    56
    thank you sip.dg for your workaround ! i think this option in a future to be insert like a selectable configuration.
