IVR Session, Sorry. Inbound Calls.
Discussion in '3CX Phone System - General' started by tj-pbx, Apr 12, 2011.
  1. tj-pbx
    Mar 4, 2011
    9
    Hi all,
    I've been searching for this issue as I am sure it is common and a solution is likely to already be out there.
    After a few months of the system working well, I arrive at the office this morning and was made aware folks cannot dial in. I checked via my mobile phone and received the prompt that an IVR session error has occurred, and disconnects the call. I was able to cold-boot the phone system and it's working well again..
    I've exported a log file when it came back on, saved to my PC. Without purchasing commercial support from 3CX, is there a way I can submit this log somewhere to find out what is causing this issue? It did happen twice before since we had the system installed. Or, any ideas what might cause this error, if the only changes we are making to the 3CX is adding extensions?
    Thanks.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Are you using Cassini? if so, restart the Cassini server.
  3. tj-pbx
    Mar 4, 2011
    9
    I don't believe so, how can I check?
  4. sigma1
    Nov 20, 2009
    542
    When you use the web portal, does the URL contain the IP address and :5481? If so it's cassini/abyss
    It is also in the Custom Parameters. What OS are you using? If it's not a Server OS they you are probably using Cassini
  5. tj-pbx
    Mar 4, 2011
    9
    3CX is running on Windows 7 OS.
  6. sigma1
    Nov 20, 2009
    542
    You are using Cassini/abyss then
  7. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Sigma is right IVR erros normally stem from failure of the abyss web server, if you are seeing these issue, please create a sheduled reboot of the web server every night.
  8. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Mark,
    Are you recommending this as a standard procedure when using a 3CX pbx running Abyss? Easy enough to do, just looking for guidance from the people who know best.
