IVR Stopped working with 2-call limit test license
Discussion in '3CX Phone System - General' started by Bob Denny, Mar 25, 2009.
  1. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    I upgraded to 7.1.6278. Then I used the 2-call limit license to test out the commercial features. After doing this, my IVR stopped working. Downgrading to the free functionality and changing NOTHING ELSE restored the IVR.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    98
    Can you explain your problem in more detail please?
  3. Bob Denny
    Feb 21, 2009
    131
    I'm not sure what else to report. The IVR stopped answering completely. Removing the 2-call license resulted in the IVR again working as configured. Nothing else was adjusted in any way.
  4. LeonidasG
    Nov 19, 2008
    1,500
    98
    After you enter your License you need to restart the PhoneSystem. You have to do the Same when downgrading or problems like these usually show up.
    Another thing to check is if you Installed the K-Lite Codec pack on that specific machine.
    If you have you need to go to :
    Start > All programs > K-Lite Codec Pack > Configuration > ffdshow audio decoder > Direct Show Control > Move the Merit Slide Bar to : Dont Use.
    If it persists, give the PBX a couple of minutes after the Restart before making calls.
    Can you call the IVR? Does the IVR Register when you start the PBX? Do you hear the ringing tone when calling the IVR? Does it give you a busy tone when calling the IVR?
