IVR stopped working with error message to callers
Discussion in '3CX Phone System - General' started by Jonners59, Mar 26, 2012.
  1. Jonners59
    Jonners59 New Member
    Apr 21, 2009
    129
    I have two analogue PSTN lines connected to my server via a Grandstream GWX FXO/FXS. I also have a VOIPTalk line too. I also have two Gigaset N330A IP DECT base stations running 3 handsets. Each also connects one of the two PSTN lines as a backup. The 3CX sits on a Windows 7 32-bit hosted ona virtual machine, which runs Linux Ubuntu 11.11 64-bit
    These are working fine and the system has worked without any intervention for the past 12 months.
    This problem start about a week ago.
    I have different call routing for each line as one is for HOME/personal and the other is for WORK. In both cases the IVR does not engage and an automated message to the caller, not very clear says something like "the IVR did not engage" or something. I have also noticed that the outbound message on voice mailboxes do not work either, it just goes straight in to the mailbox with the automated message about how to leave messages.
    It is as if the 3CX server can not access the wav files.... They all appear in their respective extension set ups and have be re attached too, and tried, yet they do not pick up.
    I have made two calls to both numbers and attached the configs.
    Code:
    09:18:58.941  [CM503003]: Call(8): Call to sip:110@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.90:5060
    09:18:58.839  Session 15541 of leg C:8.1 is confirmed
    09:18:58.809  [CM503007]: Call(8): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b
    09:18:58.744  [CM503007]: Call(8): Device joined: sip:10003@192.168.1.95:5064;transport=udp
    09:18:58.739  [MS210005] C:8.1:Answer provided. Connection(proxy mode):192.168.1.51:7056(7057)
    09:18:58.733  [MS210001] C:8.5:Answer received. RTP connection[unsecure]: 127.0.0.1:40622(40623)
    09:18:58.717  Remote SDP is set for legC:8.5
    09:18:58.717  [CM503002]: Call(8): Alerting sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b
    09:18:58.569  [CM503025]: Call(8): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b]
    09:18:58.567  [MS210004] C:8.5:Offer provided. Connection(proxy mode): 127.0.0.1:7064(7065)
    09:18:58.506  [CM503016]: Call(8): Attempt to reach <sip:801@192.168.1.51:5060> failed. Reason: Temporarily Unavailable
    09:18:58.485  [CM503003]: Call(8): Call to sip:110@192.168.1.51 has failed; Cause: 480 Temporarily not available; from IP:192.168.1.91:5060
    09:18:50.468  [CM503003]: Call(8): Call to sip:101@192.168.1.51 has failed; Cause: 503 Service Unavailable; warning: ; internal
    09:18:50.277  [CM505001]: Ext.110: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300 IP/42.051.01.000.000] PBX contact: [sip:110@192.168.1.51:5060]
    09:18:50.277  [CM503002]: Call(8): Alerting sip:110@192.168.1.90:5060
    09:18:49.329  [CM503025]: Call(8): Calling RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:101@192.168.1.61:5060]
    09:18:49.324  [MS210002] C:8.4:Offer provided. Connection(transcoding mode): 192.168.1.51:7062(7063)
    09:18:49.295  [CM503025]: Call(8): Calling RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.91:5060]
    09:18:49.291  [MS210006] C:8.3:Offer provided. Connection(by pass mode): 192.168.1.95:5012(5013)
    09:18:49.259  [CM503025]: Call(8): Calling RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.90:5060]
    09:18:49.258  [MS210006] C:8.2:Offer provided. Connection(by pass mode): 192.168.1.95:5012(5013)
    09:18:49.194  [CM503004]: Call(8): Route 1: RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.90:5060,Dev:sip:110@192.168.1.91:5060,Dev:sip:101@192.168.1.61:5060]
    09:18:49.175  [CM503010]: Making route(s) to <sip:801@192.168.1.51:5060>
    09:18:49.174  [MS210000] C:8.1:Offer received. RTP connection: 192.168.1.95:5012(5013)
    09:18:49.171  Remote SDP is set for legC:8.1
    09:18:49.169  [CM505002]: Gateway:[GWX 4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:2) 1.3.4.10] PBX contact: [sip:10003@192.168.1.51:5060]
    09:18:49.062  [CM503001]: Call(8): Incoming call from unknown@(Ln.10003@GWX 4104) to <sip:801@192.168.1.51:5060>
    09:18:49.004  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10003 forwards to DN:801
    09:18:49.004  Looking for inbound target: called=10003-10004; caller=unknown
    09:18:48.999  [CM500002]: Info on incoming INVITE:
      INVITE sip:10003-10004@192.168.1.51 SIP/2.0
      Via: SIP/2.0/UDP 192.168.1.95:5064;branch=z9hG4bK53512952c6138d50
      Max-Forwards: 70
      Contact: <sip:10003@192.168.1.95:5064;transport=udp>
      To: <sip:10003-10004@192.168.1.51>
      From: <sip:unknown@192.168.1.51>;tag=f3768500dd857144
      Call-ID: 4621df2247c57e541a73694010746115@192.168.1.95
      CSeq: 30065 INVITE
      Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK
      Proxy-Authorization: Digest username="10003",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10003-10004@192.168.1.51",nonce="414d535c0580b76803:1c9f5dae0ef909a4921dc27dbbc80dbc",response="c726db2dd0bfb782837df47f96b4746b"
      Supported: replaces, timer, path
      User-Agent: Grandstream GXW4104 (HW 1.1, Ch:2) 1.3.4.10
      Content-Length: 0
    09:18:47.642  Currently active calls [none]
    09:18:36.524  [CM503003]: Call(7): Call to sip:101@192.168.1.51 has failed; Cause: 408 Request Timeout; internal
    09:18:32.030  [CM503008]: Call(7): Call is terminated
    09:18:26.320  Session 15522 of leg C:7.1 is confirmed
    09:18:26.214  [CM503007]: Call(7): Device joined: sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008
    09:18:26.154  [CM503007]: Call(7): Device joined: sip:10001@192.168.1.95:5060;transport=udp
    09:18:26.139  [MS210005] C:7.1:Answer provided. Connection(proxy mode):192.168.1.51:7046(7047)
    09:18:26.132  [MS210001] C:7.5:Answer received. RTP connection[unsecure]: 127.0.0.1:40620(40621)
    09:18:26.126  Remote SDP is set for legC:7.5
    09:18:26.121  [CM505001]: Ext.900: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:900@127.0.0.1:5060]
    09:18:26.121  [CM503002]: Call(7): Alerting sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008
    09:18:25.935  [CM503025]: Call(7): Calling Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008]
    09:18:25.932  [MS210004] C:7.5:Offer provided. Connection(proxy mode): 127.0.0.1:7054(7055)
    09:18:25.792  [CM503005]: Call(7): Forwarding: Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008]
    09:18:18.663  Currently active calls - 1: [7]
    09:18:13.575  [CM503003]: Call(7): Call to sip:100@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.91:5060
    09:18:13.171  [CM503003]: Call(7): Call to sip:100@192.168.1.51 has failed; Cause: 480 Temporarily not available; from IP:192.168.1.90:5060
    09:18:05.156  [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300A IP/42.050.00.000.000] PBX contact: [sip:100@192.168.1.51:5060]
    09:18:05.156  [CM503002]: Call(7): Alerting sip:100@192.168.1.91:5060
    09:18:04.372  [CM503025]: Call(7): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:101@192.168.1.61:5060]
    09:18:04.370  [MS210002] C:7.4:Offer provided. Connection(transcoding mode): 192.168.1.51:7052(7053)
    09:18:04.347  [CM503025]: Call(7): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.91:5060]
    09:18:04.343  [MS210006] C:7.3:Offer provided. Connection(by pass mode): 192.168.1.95:5008(5009)
    09:18:04.319  [CM503025]: Call(7): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.90:5060]
    09:18:04.314  [MS210006] C:7.2:Offer provided. Connection(by pass mode): 192.168.1.95:5008(5009)
    09:18:04.219  [CM503004]: Call(7): Route 1: RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.90:5060,Dev:sip:100@192.168.1.91:5060,Dev:sip:101@192.168.1.61:5060]
    09:18:04.187  [CM503010]: Making route(s) to <sip:800@192.168.1.51:5060>
    09:18:04.182  [MS210000] C:7.1:Offer received. RTP connection: 192.168.1.95:5008(5009)
    09:18:04.170  Remote SDP is set for legC:7.1
    09:18:04.168  [CM505002]: Gateway:[GWX 4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:1) 1.3.4.10] PBX contact: [sip:10001@192.168.1.51:5060]
    09:18:04.033  [CM503001]: Call(7): Incoming call from 07770740133@(Ln.10001@GWX 4104) to <sip:800@192.168.1.51:5060>
    09:18:04.008  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:800
    09:18:04.008  Looking for inbound target: called=10001-10002; caller=07770740133
    09:18:03.998  [CM500002]: Info on incoming INVITE:
      INVITE sip:10001-10002@192.168.1.51 SIP/2.0
      Via: SIP/2.0/UDP 192.168.1.95:5060;branch=z9hG4bK59f0071341b743a2
      Max-Forwards: 70
      Contact: <sip:10001@192.168.1.95:5060;transport=udp>
      To: <sip:10001-10002@192.168.1.51>
      From: <sip:07770740133@192.168.1.51>;tag=b4e39706a8e68724
      Call-ID: c9d0b66144f49046efe102660f045630@192.168.1.95
      CSeq: 17463 INVITE
      Proxy-Authorization: Digest username="10001",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10001-10002@192.168.1.51",nonce="414d535c0580b73b66:e315e76a04a7c4f60ef13976b3d4a5be",response="c1eb7e1aae352f1a422c1502b619279b"
      User-Agent: Grandstream GXW4104 (HW 1.1, Ch:1) 1.3.4.10
      Content-Length: 0
    09:17:47.478  Currently active calls [none]
    09:17:17.371  Currently active calls [none]
    09:16:47.000  Currently active calls [none]
    09:16:16.378  Currently active calls [none]
    09:15:46.789  Currently active calls [none]
    09:15:37.973  [CM503003]: Call(5): Call to sip:101@192.168.1.51 has failed; Cause: 408 Request Timeout; internal
    09:15:32.761  [CM503008]: Call(5): Call is terminated
    09:15:31.925  [CM503008]: Call(6): Call is terminated
    09:15:26.884  Session 15459 of leg C:5.1 is confirmed
    and again
    Code:
    09:15:26.743  [CM503007]: Call(5): Device joined: sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008
    09:15:26.675  [CM503007]: Call(5): Device joined: sip:10001@192.168.1.95:5060;transport=udp
    09:15:26.656  [MS210005] C:5.1:Answer provided. Connection(proxy mode):192.168.1.51:7032(7033)
    09:15:26.640  [MS210001] C:5.5:Answer received. RTP connection[unsecure]: 127.0.0.1:40618(40619)
    09:15:26.636  Remote SDP is set for legC:5.5
    09:15:26.624  [CM505001]: Ext.900: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:900@127.0.0.1:5060]
    09:15:26.624  [CM503002]: Call(5): Alerting sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008
    09:15:26.297  [CM503025]: Call(5): Calling Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008]
    09:15:26.293  [MS210004] C:5.5:Offer provided. Connection(proxy mode): 127.0.0.1:7044(7045)
    09:15:26.247  Session 15471 of leg C:6.1 is confirmed
    09:15:26.172  [CM503005]: Call(5): Forwarding: Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=b9a155f9ad6c9008]
    09:15:26.070  [CM503007]: Call(6): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b
    09:15:25.914  [CM503007]: Call(6): Device joined: sip:100@192.168.1.91:5060
    09:15:25.888  [MS210005] C:6.1:Answer provided. Connection(proxy mode):192.168.1.51:7040(7041)
    09:15:25.883  [MS210001] C:6.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40616(40617)
    09:15:25.878  Remote SDP is set for legC:6.2
    09:15:25.868  [CM503002]: Call(6): Alerting sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b
    09:15:25.689  [CM503025]: Call(6): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b]
    09:15:25.685  [MS210004] C:6.2:Offer provided. Connection(proxy mode): 127.0.0.1:7042(7043)
    09:15:25.639  [CM503016]: Call(6): Attempt to reach <sip:1470170940090@192.168.1.51;user=phone> failed. Reason: Not Found
    09:15:25.638  [CM503014]: Call(6): No known route to target: <sip:1470170940090@192.168.1.51;user=phone>
    09:15:25.564  [CM503010]: Making route(s) to <sip:1470170940090@192.168.1.51;user=phone>
    09:15:25.564  [MS210000] C:6.1:Offer received. RTP connection: 192.168.1.91:5010(5011)
    09:15:25.560  Remote SDP is set for legC:6.1
    09:15:25.558  [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300A IP/42.050.00.000.000] PBX contact: [sip:100@192.168.1.51:5060]
    09:15:25.452  [CM503001]: Call(6): Incoming call from Ext.100 to <sip:1470170940090@192.168.1.51;user=phone>
    09:15:25.432  [CM500002]: Info on incoming INVITE:
      INVITE sip:1470170940090@192.168.1.51;user=phone SIP/2.0
      Via: SIP/2.0/UDP 192.168.1.91:5060;branch=z9hG4bK2fc374dd9fff131f41134b57f480e14;rport=5060
      Max-Forwards: 70
      Contact: <sip:100@192.168.1.91:5060>
      To: <sip:1470170940090@192.168.1.51;user=phone>
      From: "Baroni Limited"<sip:100@192.168.1.51>;tag=3074029216
      Call-ID: 3948065209@192_168_1_91
      CSeq: 3 INVITE
      Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, REFER, SUBSCRIBE, NOTIFY
      Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:1470170940090@192.168.1.51;user=phone",nonce="414d535c0580b69d79:217ae06fb49919e9caa09e0c9d67cd7a",response="6fd3e471961316659f7a2cb5aec3edf6"
      Supported: replaces
      User-Agent: N300A IP/42.050.00.000.000
      Allow-Events: message-summary, refer, ua-profile, talk
      Content-Length: 0
    09:15:15.956  Currently active calls - 1: [5]
    09:15:14.701  [CM503003]: Call(5): Call to sip:100@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.91:5060
    09:15:14.413  [CM503003]: Call(5): Call to sip:100@192.168.1.51 has failed; Cause: 480 Temporarily not available; from IP:192.168.1.90:5060
    09:15:06.668  [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300A IP/42.050.00.000.000] PBX contact: [sip:100@192.168.1.51:5060]
    09:15:06.668  [CM503002]: Call(5): Alerting sip:100@192.168.1.91:5060
    09:15:05.846  [CM503025]: Call(5): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:101@192.168.1.61:5060]
    09:15:05.843  [MS210002] C:5.4:Offer provided. Connection(transcoding mode): 192.168.1.51:7038(7039)
    09:15:05.826  [CM503025]: Call(5): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.91:5060]
    09:15:05.824  [MS210006] C:5.3:Offer provided. Connection(by pass mode): 192.168.1.95:5004(5005)
    09:15:05.804  [CM503025]: Call(5): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.90:5060]
    09:15:05.800  [MS210006] C:5.2:Offer provided. Connection(by pass mode): 192.168.1.95:5004(5005)
    09:15:05.755  [CM503004]: Call(5): Route 1: RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.90:5060,Dev:sip:100@192.168.1.91:5060,Dev:sip:101@192.168.1.61:5060]
    09:15:05.577  [CM503010]: Making route(s) to <sip:800@192.168.1.51:5060>
    09:15:05.577  [MS210000] C:5.1:Offer received. RTP connection: 192.168.1.95:5004(5005)
    09:15:05.572  Remote SDP is set for legC:5.1
    09:15:05.569  [CM505002]: Gateway:[GWX 4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:0) 1.3.4.10] PBX contact: [sip:10001@192.168.1.51:5060]
    09:15:05.501  [CM503001]: Call(5): Incoming call from 07770740133@(Ln.10001@GWX 4104) to <sip:800@192.168.1.51:5060>
    09:15:05.471  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:800
    09:15:05.446  Looking for inbound target: called=10001-10002; caller=07770740133
    09:15:05.381  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP 192.168.1.95:5060;branch=z9hG4bKc85784a43cf7a483
      Max-Forwards: 70
      From: <sip:07770740133@192.168.1.51>;tag=18e3bc7135700554
      Call-ID: 80666b907ae0ae40aeb13d84589278a5@192.168.1.95
      CSeq: 20965 INVITE
      Proxy-Authorization: Digest username="10001",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10001-10002@192.168.1.51",nonce="414d535c0580b68946:8e98f109110bacc9a4cea0941ea75d50",response="9b17c586b988c7e7ec2bd29bc222caf4"
      User-Agent: Grandstream GXW4104 (HW 1.1, Ch:0) 1.3.4.10
      Content-Length: 0
    09:14:45.787  Currently active calls [none]
    09:14:15.725  Currently active calls [none]
    09:13:45.619  Currently active calls [none]
    09:13:15.400  Currently active calls [none]
    09:12:45.328  Currently active calls [none]
    09:12:15.267  Currently active calls [none]
    09:11:45.203  Currently active calls [none]
    09:11:15.066  Currently active calls [none]
    09:10:44.594  Currently active calls [none]
    09:10:15.351  Currently active calls [none]
    09:10:09.722  [CM503008]: Call(4): Call is terminated
    09:10:02.940  Session 15366 of leg C:4.1 is confirmed
    09:10:02.841  [CM503007]: Call(4): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b
    09:10:02.794  [CM503007]: Call(4): Device joined: sip:10003@192.168.1.95:5064;transport=udp
    09:10:02.789  [MS210005] C:4.1:Answer provided. Connection(proxy mode):192.168.1.51:7022(7023)
    09:10:02.784  [MS210001] C:4.5:Answer received. RTP connection[unsecure]: 127.0.0.1:40614(40615)
    09:10:02.779  Remote SDP is set for legC:4.5
    09:10:02.554  [CM503002]: Call(4): Alerting sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b
    09:10:02.354  [CM503003]: Call(4): Call to sip:110@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.90:5060
    09:10:02.099  [CM503025]: Call(4): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=8a1c59101f31d83b]
    09:10:02.099  [MS210004] C:4.5:Offer provided. Connection(proxy mode): 127.0.0.1:7030(7031)
    09:10:02.026  [CM503016]: Call(4): Attempt to reach <sip:801@192.168.1.51:5060> failed. Reason: Temporarily Unavailable
  2. Jonners59
    Apr 21, 2009
    129
    I have just tried changing the prompt set language and restarted the system.
    Same arror message...
    Logs again
    Code:
    10:14:25.691  [CM503008]: Call(2): Call is terminated
    10:14:19.000  Session 239 of leg C:2.1 is confirmed
    10:14:18.995  [CM503003]: Call(2): Call to sip:100@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.91:5060
    10:14:18.950  [CM503007]: Call(2): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=afb1c1c32574095e
    10:14:18.888  [CM503007]: Call(2): Device joined: sip:10001@192.168.1.95:5060;transport=udp
    10:14:18.888  [MS210005] C:2.1:Answer provided. Connection(proxy mode):192.168.1.51:7008(7009)
    10:14:18.877  [MS210001] C:2.4:Answer received. RTP connection[unsecure]: 127.0.0.1:40612(40613)
    10:14:18.871  Remote SDP is set for legC:2.4
    10:14:18.871  [CM503002]: Call(2): Alerting sip:EndCall@127.0.0.1:40600;rinstance=afb1c1c32574095e
    10:14:18.631  [CM503025]: Call(2): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=afb1c1c32574095e]
    10:14:18.626  [MS210004] C:2.4:Offer provided. Connection(proxy mode): 127.0.0.1:7014(7015)
    10:14:18.548  [CM503016]: Call(2): Attempt to reach <sip:800@192.168.1.51:5060> failed. Reason: Temporarily Unavailable
    10:14:18.472  [CM503003]: Call(2): Call to sip:100@192.168.1.51 has failed; Cause: 480 Temporarily not available; from IP:192.168.1.90:5060
    10:14:10.163  [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300A IP/42.050.00.000.000] PBX contact: [sip:100@192.168.1.51:5060]
    10:14:10.163  [CM503002]: Call(2): Alerting sip:100@192.168.1.91:5060
    10:14:08.833  [CM503025]: Call(2): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.91:5060]
    10:14:08.832  [MS210006] C:2.3:Offer provided. Connection(by pass mode): 192.168.1.95:5020(5021)
    10:14:08.807  [CM503025]: Call(2): Calling RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.90:5060]
    10:14:08.798  [MS210006] C:2.2:Offer provided. Connection(by pass mode): 192.168.1.95:5020(5021)
    10:14:08.726  [CM503004]: Call(2): Route 1: RingAll800:100Ext.100101Ext.101102103Ext.103105Ext.105@[Dev:sip:100@192.168.1.90:5060,Dev:sip:100@192.168.1.91:5060]
    10:14:08.616  [CM503010]: Making route(s) to <sip:800@192.168.1.51:5060>
    10:14:08.616  [MS210000] C:2.1:Offer received. RTP connection: 192.168.1.95:5020(5021)
    10:14:08.611  Remote SDP is set for legC:2.1
    10:14:08.609  [CM505002]: Gateway:[GWX 4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:4) 1.3.4.10] PBX contact: [sip:10001@192.168.1.51:5060]
    10:14:08.512  [CM503001]: Call(2): Incoming call from 07770740133@(Ln.10001@GWX 4104) to <sip:800@192.168.1.51:5060>
    10:14:08.461  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:800
    10:14:08.445  Looking for inbound target: called=10001-10002; caller=07770740133
    10:14:08.434  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP 192.168.1.95:5060;branch=z9hG4bK46060f74f4532862
      Max-Forwards: 70
      From: <sip:07770740133@192.168.1.51>;tag=4d0172752657b7f1
      Call-ID: ab35c153aaa56da5fab289877cb3bad2@192.168.1.95
      CSeq: 29730 INVITE
      Proxy-Authorization: Digest username="10001",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10001-10002@192.168.1.51",nonce="414d535c0580c46044:8b52367f785ab15c7bfadc4e2c8e1d60",response="c90f6a1a7606a8595c541a9bf7724da4"
      User-Agent: Grandstream GXW4104 (HW 1.1, Ch:4) 1.3.4.10
      Content-Length: 0
    10:14:03.774  Currently active calls [none]
    10:13:41.303  [CM503008]: Call(1): Call is terminated
    10:13:36.599  Currently active calls - 1: [1]
    10:13:36.066  Session 209 of leg C:1.1 is confirmed
    10:13:36.035  [CM503007]: Call(1): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=afb1c1c32574095e
    10:13:35.988  [CM503007]: Call(1): Device joined: sip:10003@192.168.1.95:5064;transport=udp
    10:13:35.984  [MS210005] C:1.1:Answer provided. Connection(proxy mode):192.168.1.51:7000(7001)
    10:13:35.980  [MS210001] C:1.4:Answer received. RTP connection[unsecure]: 127.0.0.1:40610(40611)
    10:13:35.976  Remote SDP is set for legC:1.4
    10:13:35.912  [CM503003]: Call(1): Call to sip:110@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.90:5060
    10:13:35.886  [CM503002]: Call(1): Alerting sip:EndCall@127.0.0.1:40600;rinstance=afb1c1c32574095e
    10:13:35.712  [CM503025]: Call(1): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=afb1c1c32574095e]
    10:13:35.709  [MS210004] C:1.4:Offer provided. Connection(proxy mode): 127.0.0.1:7006(7007)
    10:13:35.662  [CM503016]: Call(1): Attempt to reach <sip:801@192.168.1.51:5060> failed. Reason: Temporarily Unavailable
    10:13:35.627  [CM503003]: Call(1): Call to sip:110@192.168.1.51 has failed; Cause: 480 Temporarily not available; from IP:192.168.1.91:5060
    10:13:30.087  [CM505001]: Ext.110: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300 IP/42.051.01.000.000] PBX contact: [sip:110@192.168.1.51:5060]
    10:13:30.087  [CM503002]: Call(1): Alerting sip:110@192.168.1.90:5060
    10:13:29.421  [CM503025]: Call(1): Calling RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.91:5060]
    10:13:29.419  [MS210006] C:1.3:Offer provided. Connection(by pass mode): 192.168.1.95:5016(5017)
    10:13:29.398  [CM503025]: Call(1): Calling RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.90:5060]
    10:13:29.387  [MS210006] C:1.2:Offer provided. Connection(by pass mode): 192.168.1.95:5016(5017)
    10:13:29.332  [CM503004]: Call(1): Route 1: RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.90:5060,Dev:sip:110@192.168.1.91:5060]
    10:13:29.229  [MS210000] C:1.1:Offer received. RTP connection: 192.168.1.95:5016(5017)
    10:13:29.222  [CM503010]: Making route(s) to <sip:801@192.168.1.51:5060>
    10:13:29.194  Remote SDP is set for legC:1.1
    10:13:29.113  [CM505002]: Gateway:[GWX 4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:3) 1.3.4.10] PBX contact: [sip:10003@192.168.1.51:5060]
    10:13:29.037  [CM503001]: Call(1): Incoming call from unknown@(Ln.10003@GWX 4104) to <sip:801@192.168.1.51:5060>
    10:13:28.489  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10003 forwards to DN:801
    10:13:28.478  Looking for inbound target: called=10003-10004; caller=unknown
    10:13:28.463  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP 192.168.1.95:5064;branch=z9hG4bKea17a5b0506423c1
      Max-Forwards: 70
      From: <sip:unknown@192.168.1.51>;tag=59d57e150dc450b7
      Call-ID: 6a73e8b4cbb28c451e078cb67c36c887@192.168.1.95
      CSeq: 5884 INVITE
      Proxy-Authorization: Digest username="10003",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10003-10004@192.168.1.51",nonce="414d535c0580c43838:2440db269ce7f1b8e89ff892216e23e8",response="0588dd9efb87b5b5abb5a767d060d163"
      User-Agent: Grandstream GXW4104 (HW 1.1, Ch:3) 1.3.4.10
      Content-Length: 0
    10:13:16.163  Currently active calls [none]
    10:13:00.551  Currently active calls [none]
    10:12:45.495  Currently active calls [none]
    10:12:30.350  Currently active calls [none]
    10:12:18.023  [CM504001]: Ext.110: new contact is registered. Contact(s): [sip:110@192.168.1.90:5060/110,sip:110@192.168.1.91:5060/110]
    10:12:17.969  [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.1.90:5060/100,sip:100@192.168.1.91:5060/100]
    10:12:15.008  Currently active calls [none]
    10:12:10.739  [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.1.90:5060/100]
    10:12:10.048  [CM504001]: Ext.110: new contact is registered. Contact(s): [sip:110@192.168.1.90:5060/110]
    10:12:02.690  [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    10:12:02.678  [CM504002]: Ext.110: a contact is unregistered. Contact(s): []
    10:12:02.678  [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    10:11:55.255  Currently active calls [none]
    10:10:23.386  Currently active calls [none]
  3. leejor
    11,086
    325
    Were any updates done to the operating system? You don't say which version of windows you are running. Something must have changed for the system to stop after 12 months of running OK. Audio files/drivers? Will the system play a wav file?
  4. Jonners59
    Apr 21, 2009
    129
    WIndows7 Home Prem 32-bit
    All updates are installed automatically.
    I ONLY use it for the 3CX. It is a virtual install. I.e. the main op is Linux - Ubuntu 11.011 64-bit (also up to date) running Virtuual Box, also always kept up to date.
    I do not tend to run audio files from this PC as it is just used for storage, as a source for accessing stored media for the TV and the VM running the 3CX
    I have used 3CX for a number of years in this coinfiguration and had no issues for c12 months, as you have noted. It is odd.
    I am out at at meetings all day so shall try audio files when I get back.
    PS: Thanks for looking in and getting back.
  5. leejor
    11,086
    325
    You may want to see if something was updated/installed about the time that you began having the audio issues.
  6. Jonners59
    Apr 21, 2009
    129
    OK, had another look, though not conclusive.
    I tried playing audio files via my Ubuntu and the Windows and neither played. I tried the headset I was using oin another machine and they worked fine. So I think my adio card may be US...
    Now, that may be miss leading because the warning messages play when someone calls. If the audio card was the issue then they would not play either!!!!
    Updates, that is hard to say too as it is not clear exactly when it stopped. One thing I can say, is it was c the time we were hit by the sun's radio waves the other Friday. I lost my Siemens DECT base station at the same time, and had to replace it. I am wondering if it may have knocked out the audio card too, but it still does not explain the 3CX audio on incoiming calls.
    The message seems to be more about routing the call to the IVR and Voice Mail extensions than just playing the messages, or at least accessing the messages in the first place. I know they are there and I can access them via the 3CX set up, the Windows7 desktop, the Ubuntu desktop and the LAN....
    I saw that someone else had a similar issue on a Server version, but thiers was resolved by changing default language back and forth, which I tried to no avail.
  7. leejor
    11,086
    325
    Do you get any sort of error message when you try to play audio? If you can get your hands on another audio card, and get that to work, it may just be related to the issue. It may also be an audio software problem. I would focus on figuring out why you don't get audio. If the solar flares were as bad in your area as to affect your DECT phone, then you may be on to something.
  8. Jonners59
    Apr 21, 2009
    129
    There is no error message when playing the wave files. Just nothing comes out...
    But what I don't. Understand is why then if it is an audio card prob The caller gets the 3CX IVR error message or the no routes available messages... the surely be no sound?
