IVR stopping V14 + Windows 10..
Discussion in '3CX Phone System - General' started by Jean Turcotte, Mar 15, 2017.
  1. Jean Turcotte
    Mar 15, 2017
    Hi!
    This morning couldn't get a client IVR to work on Version 14, the service was stopping.. couldn't find a reason until a dig up a little.. and found the problem! On windows 10 the KB4013429 update the file CompPkgSup.dll. you need to put back a older version or remove the update to get a older file ( new files date is 04-03-2017) after that the IVR will work again...
    I hope that will help someone!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Thank you for sharing your solution to the forum memders
